Old 05-07-2019, 08:29 AM   #1
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Sync odometer from cluster to ECM
My daughter has a 2000 Silverado 1500 and it has 287k on it. We replaced the cluster with one from a boneyard because the PRDL display was missing.. The new cluster has 150k on the odometer. Is there a way to sync the new cluster with the ECM to show the correct mileage?
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 05-07-2019, 02:01 PM   #2
shifty
Questionable
shifty's Avatar
Re: Sync odometer from cluster to ECM
This thread from GMT400 covers adjusting the odometer part: https://www.gmt400.com/threads/clust...5/#post-449362
I have no idea how to get the actual mileage out of the ECM though.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 05-07-2019, 02:16 PM   #3
61_FL_Apache
Who Me?
This one has a digital display, but the mileage is stored in the cluster somewhere. We hooked up a fancy scan tool and it was able to tell us the mileage from the ECM. I figured the cluster would read that info from the ECM and display it on the cluster.
The link you sent is for analog odometers.
The picture in this link will show you the digital display.
https://www.bing.com/images/search?v...vt=0&eim=1,2,6
Steve
2001 Blazer 4D 2WD
Old 05-07-2019, 04:40 PM   #4
shifty
Questionable
shifty's Avatar
Ah! That's the 99-06 NBS cluster. I thought maybe she had a 00 OBS old cluster or something because this was posted in the 88-98 forum.
Might have more luck posting in the next generation's subforum dealing with 99-06. Not sure how much that one is frequented though.
Old 05-07-2019, 04:51 PM   #5
61_FL_Apache
Who Me?
Crap! My bad on wrong post location! I will re-post there.
Steve
2001 Blazer 4D 2WD
Old 05-07-2019, 08:41 PM   #6
I moved it for you Steve, then saw your other one. so I hid it so there is only one and now one yelss at you or sends you to facebook jail
Old 05-08-2019, 07:13 AM   #7
61_FL_Apache
Who Me?
Thank you Bill!
Steve
2001 Blazer 4D 2WD
Old 05-08-2019, 11:30 AM   #8
hatzie
Moderator
hatzie's Avatar
There are at least two generations of T800 clusters. First design was 99-02. 03-07 used a different cluster than the first design trucks. I'm not positive that the 99 cluster can be used on 00-02 vehicles...
I thought the PCM or BCM got its' mileage info from the cluster so once you plug in the new cluster and mate it to the system the controller will have the mileage from the new cluster.
If you have a record of the mileage from the old cluster... There are tools that that will allow you to adjust the mileage to match the old cluster. They aren't cheap.
The tool to re-program clusters is not inexpensive. I'd get the original cluster repaired and swap it back in or take it to a speedometer repair outfit and get the replacement odometer matched to the old one. You may be able to horsetrade the old cluster for the odometer match.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 05-09-2019, 07:43 AM   #9
61_FL_Apache
Who Me?
Thank you for the feedback John.
Steve
2001 Blazer 4D 2WD
Old 05-20-2019, 01:42 PM   #10
mMad Dawg
I replaced the cluster in my 2000 Silverado. I plugged it in and turned the key on. It read the the mileage of the old truck. I turned the key off and then started my truck. It now reads my original mileage. No scan tool. Hope this helps. Gord
mMad Dawg is offline   Reply With Quote
Old 05-24-2019, 08:29 AM   #11
truckdude239
truckdude239's Avatar
Mileage is stored in the cluster only way to get proer mileage is to send cluster out for reprogram or unsolider swap the prom chips off the boards
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 05-26-2019, 12:40 AM   #12
EVRLET
EVRLET's Avatar
Agreed. Mileage is stored in the cluster and not the PCM. Verified this today because I picked up an NBS cluster with trans temp. My old and new cluster work fine and they displayed different mileages.
Customization is what you want it to look like -- not what other people think it should look like
EVRLET is offline   Reply With Quote
