05-07-2019, 01:03 PM | #1 |
Pitman arm
I am converting my 67 K10 over to power steering. I still have my 67 closed knuckle axle. Does anybody make, or have a pitman arm that will work? Skyjacker is for an open knuckle. Thanks John
05-07-2019, 08:07 PM | #2 |
Roto Reuter thats the name...
Re: Pitman arm
Not sure about the application issue or why it wouldn't work. I have a 70 K10 open knuckle with PS and 2-1/2" skyjacker lift. I'm swapping out my stock pitman arm with one made for the lift. I still have the original pitman arm if your interested or want pictures. I know it's open knuckle but I have no idea what the difference would be in the pitman arm. Maybe you should post this in the classified as WTB.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
05-08-2019, 01:02 PM | #3 |
Re: Pitman arm
After researching more, I found that there was a one year only steering arm required 1969. I think will just upgrade to a newer axle.
05-08-2019, 01:15 PM | #4 |
Re: Pitman arm
stock pitman arm on 4x4 box works fine with no lift. The steering arm on a closed knuckle has to be shortened and a new drag link made.
1961 chevy K10 my build is------------61K10 build |
