transfer case mounts.
Hello everyone,
Is there a trick to getting the transfer case mounts on? I can't seem to get it. I had my transfer case out to change the seals in the adapter and while pulling it atf got all over the mounts. I took them off to clean the area up and now can't get them back on. The mounts are polyurethane and still like new. I'm sure they're the right ones because they were on there fine before. The crazy thing is I put them on a few years ago and now can't get it. Thanks in advance for any help. |
![]() Join Date: Sep 2017
Re: transfer case mounts.
The mounts on the passenger frame rail or on the crossmember?
WTB 71-72 Original paint Medium Red hood WTB 1972 Very nice original Parchment seat belt set |
Here is the tcase mount out of the shop manual
here it is in pic
It's the crossmember mounts. What I'm having trouble with is the crossmember has a big lip around the bolt holes that the mounts seat into. I can't get the mounts to seat properly on the crossmember. It's hard to explain unless you've seen it. When I get home from work I'll take a picture.
Okay, I figured out the problem. I'm stupid. The mounts have a plastic insert in them that go through the bolt holes. When I remove the mounts from the crossmember they pulled out of the mounts and remained in the crossmember. It looked like they were part of the crossmember itself. When I tried to reinstall the mounts I was trying to get them reseated on the plastic inserts and there was no way that was happening. So problem solved. I feel really dumb and was going to let this thread drift off into obscurity but decided to bite the bullet and confess.
