POL Sway bars 1960-1962
Anyone install the POL swaybars onto a 1960 through 62 front and rear suspension?
The front - do I need to install the spacers between the brackets and the frame? They have goofy brackets for the rear end links as well. I want to see how they look installed. And any other tips welcomed.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Re: POL Sway bars 1960-1962
I have not but make sure the rear bar is actually for a 62. I have seen many companies list 63-66 sway bars as if they fit a 62. Let us know if it fits. I have been looking a long time for one that will actually fit on a 62. When I ordered a sway bar for a 77 c10 that was lowered 2 inches in the front I needed the spacers.
#3 | |
https://www.performanceonline.com/19...ormance-front/ https://www.performanceonline.com/19...r-Coil-Spring/
#4 | |
I used POL rear sway bar on my 62. The install was pretty straight forward. I ordered the "lowered" kit but the bolts were still to long so i had to replace the bolts and eliminate the spacer. Im happy with the quality and performance.
Sweet!
![]() Join Date: Oct 2006
I purchased a front one but have yet to install it....
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
How much is yours lowered in the rear?
I used to have one on a '61, but wasn't happy about having something straddling my trailing arms so close to the ground. I scrapped that thing, thinking i would get a junkyard version that more closely followed the rear end, but after driving without it for a while I never even missed it so I just stuck with the front end only.
Installed the sway bars. not a big deal, just lots of drilling.
Now I have do decide if I want Santa to bring me a rear sway bar or a subwoofer for Christmas.
#13 |
Sway bar is more fun, it actually fits in the truck as compared to a sub. And you can find a sub on craigslist.
#14 |
Nice!! So you have to drill into the lower control arm? Any chance you can post a close up picture of the LCA mount please ?
#15 | |
As a matter of fact, I have two extra that came with the rear kit that weren't needed. PM me
#16 |
I am in the middle of installing a rear sway bar and am wondering how much should I torque down the long bolts with the bushings.
