Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 06-14-2019, 07:03 AM   #1
dirish
dirish's Avatar
Th350 shift linkage hitting exhaust
Any one use the lokaR kit? Tight on funds, can't afford to
Choose wrong one. The piece with spring, from tranny hits exhaust when shifting from park into gear. I dI'd see on pick up side, but not sure about blazer. Thanks in advance!
Dan
dirish is offline   Reply With Quote
Old 06-14-2019, 09:02 AM   #2
dirish
dirish's Avatar
Re: Th350 shift linkage hitting exhaust
[quote=dirish;8542174]Any one use the lokaR kit? Tight on funds, can't afford to
Can this be moved to message board? Thanks
Old 06-15-2019, 07:08 AM   #3
jaros44sr
jaros44sr's Avatar
floor mount or trans mount?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 06-15-2019, 07:35 AM   #4
dirish
dirish's Avatar
I ended up flipping the bracket with spring on it upside down.
Not sure why I didn't do it earlier. It shifts perfect. I'm not a mechanic, but dang, so simple I almost missed it.
th350 shift linkage
