Old 06-18-2019, 06:15 PM   #1
Bandit130
Bandit130's Avatar
Windshield Thickness
Anyone know the thickness of the factory windshield? I have searched internet and only found one that listed as 6mm. Not sure if that is correct or correct for these trucks.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 06-18-2019, 06:39 PM   #2
sweetk30
sweetk30's Avatar
Re: Windshield Thickness
got 2 hanging on the shop wall now .
oem unit i know for sure is 6mm
2nd unit not sure if oem or aftermarket but 5mm
glad to help .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 06-18-2019, 07:09 PM   #3
Bandit130
Bandit130's Avatar
glad to help .
Thanks for the measurements. Don't remember using metric back then but I guess it is possible.
Mopar by Birth
Chevy by Choice
Old 06-19-2019, 01:15 PM   #4
SunSoaked
SunSoaked's Avatar
So easy a "caveman" can do it.
SunSoaked is offline   Reply With Quote
Old 06-19-2019, 02:36 PM   #5
Bandit130
Bandit130's Avatar
I know all about that. I worked at a valve manufacturing plant from 74 to 86. 6 of those years were as an inspector and we only used decimal measurements. We did not use metric then. Metric has become more common since then.
Mopar by Birth
Chevy by Choice
Old 06-19-2019, 02:53 PM   #6
Devilman
I've got a customer that's having a glass manufacturer build him "quiet" glass for his windshield, rear window and sides for his crew cab like they use in higher end luxury cars. The stock windshield was 6mm if I remember correctly when I got him measurements. Haven't gotten the new glass yet but I'm sure they'll be as thick or thicker than stock on the front and rear, the sides are suppose to be 2mm thicker than stock. Not sure how well it'll help with quieting down the truck but we'll see....I know it's definitely a LOT more expensive than factory replacement glass lol
Devilman is offline   Reply With Quote
Old 06-19-2019, 06:57 PM   #7
fordguy40
Is '73-'80 windshield glass thicker than '81-'87 ('91)?
A few Fords and a couple of Chevys
fordguy40 is offline   Reply With Quote
Old 06-19-2019, 09:40 PM   #8
buffydores
buffydores's Avatar
I'd love to learn the name of the manufacturer willing to do this.
Old 06-27-2019, 09:07 PM   #9
Super_Dave
Super_Dave's Avatar
My '74 is .290"
The replacement is .170 and couldn't find any OEM thickness anywhere.
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair
"Life is tough - wear a cup!"
"Old Enough to Know Better - Too Young to Resist"
"Junk is something you will need three weeks after you throw it away."
Super_Dave is offline   Reply With Quote
Old 06-27-2019, 09:32 PM   #10
Bandit130
Bandit130's Avatar
Originally Posted by Super_Dave View Post
My '74 is .290"
Thank you. That is thicker than the previous stated thickness by someone of 6mm. 6mm converts to .236. .290 converts to 7.5mm. I know for sure that when I get mine replaced, hopefully soon, I will measure it and report back.
Mopar by Birth
Chevy by Choice
