Old 06-23-2019, 03:02 PM   #1
cdub2010
looking for alcoa rims c30 - what fits?
Im looking for a set of the 8 hole Alcoa rims.
no semi rims for me. What fits my 1988 c30? Ive tried looking on the web but all I get is garbage ads for crap. Do any ford or dodge rims fit? Do the chevy rims from 89 and up fit squarebodys?
cdub2010 is offline   Reply With Quote
Old 06-26-2019, 10:10 PM   #2
rwhit57
rwhit57's Avatar
Re: looking for alcoa rims c30 - what fits?
There are aftermarket ones on Ebay. Ad says Alcoa style. They're like $650 range and look good. The fit is correct. I'm thinking about a set for my truck.
"Whoever said money can't buy happiness has obviously never seen a speed shop!
rwhit57 is offline   Reply With Quote
Old 06-28-2019, 09:17 PM   #3
1967KaiserM715
1967KaiserM715's Avatar
Chevy rims up to 2002 OLD style truck, new style 2000 and up have the wrong Hub Bore.
you want a rim with a 4.567 inch center hub bore. Newer duallys use a 4.88 hub bore.
hub bore is important IF the rims use the clamping plates or flanged lug-nuts.
some Alcoa rims are stud centered, and hub bore is not as critical. these typically use a shanked lug nut or a tapered lug nut.
stud pattern is 8x 6.5" up to 2010, they then went to a 8x180mm stud pattern.
1967KaiserM715 is offline   Reply With Quote
