Old 06-28-2019, 09:51 PM   #1
oldwagon
oldwagon's Avatar
Rear axle springs
Wanting to find out what the standard amount of leaves would be in the rear axle springs on my 83 1 ton 4x4. There are nine leaves with two helpers right now. The truck was originally used to pull a goose neck.
oldwagon is offline   Reply With Quote
Old 06-29-2019, 11:00 AM   #2
sweetk30
sweetk30's Avatar
Re: Rear axle springs
1tons tend to have 9 leaf + overload in the rear for the main pack . then 1 or more extra on top if it calls for helper leafs .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 06-29-2019, 01:27 PM   #3
1967KaiserM715
1967KaiserM715's Avatar
1 tons had between 8/1 and 12/1 springs, not including any helper springs. typically 1-3 helper springs.
8/1 is 8 leafs with the 1 fat thick overload at the bottom, so on and so forth.
1967KaiserM715 is offline   Reply With Quote
Old 06-29-2019, 01:49 PM   #4
rwhit57
rwhit57's Avatar
My 89 C3500 cab and chassis has 8 plus an overload at the top and a fat one at the bottom.
"Whoever said money can't buy happiness has obviously never seen a speed shop!
rwhit57 is offline   Reply With Quote
Old 06-29-2019, 03:52 PM   #5
oldwagon
oldwagon's Avatar
Appreciate the info. Thanks.
