Old 06-29-2019, 07:23 AM   #1
dragonlovestrucks
AC Swap? (82+ -> 77)
Hey there -
I've got a 77 C10 350 with factory air, but the compressor is missing.
Can I go grab components from some early 80s models that are sitting in a junkyard?
On my previous vehicle, when I swapped out a compressor, I also had to replace the receive dryer.
I assume on this one that would be the case, along with evac-ing the system for an extended period of time.
Has anyone had any experience with this? What about converting connections to R134a? What do I need to grab?
My thinking is that if it is in a junkyard with decent turnover, while the cars could have had R12 initially, they all would have swapped over.
dragonlovestrucks is offline   Reply With Quote
Old 06-29-2019, 01:27 PM   #2
Dead Parrot
Re: AC Swap? (82+ -> 77)
At some point, they switched from the long round compressor to the short flat one. As long as you get all needed brackets, either should work. The long round compressor is generally considered the better of the pair. You should plan on replacing the matching hose set. If your hose set is original, it is probably end of life. The high pressure hose that runs from the condenser output over to the expansion valve seems to last a lot longer. Also plan on a new expansion valve/filter unit.
Despite all the warnings about replacing the drier, when I put a new compressor on my 75, I kept the original as the replacements all required several pieces of pipe to fit in. Everything is still working fine about 15 years or more later. I did leave in under a vacuum for several hours after installing the new compressor. Went back with R-12 as I had a case purchased just before the phase out deadline.
Dead Parrot is offline   Reply With Quote
Old 06-29-2019, 01:42 PM   #3
Matt Man
Matt Man's Avatar
I think the early 80's AC trucks still had the giant old style compressor.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 06-29-2019, 01:46 PM   #4
Bandit130
Bandit130's Avatar
Welcome to the site
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 06-29-2019, 06:33 PM   #5
dragonlovestrucks
Originally Posted by Bandit130 View Post
Welcome to the site
Thank you sir!
Here is another sweet thread on this topic.
https://www.gm***************/thread...nversion.9684/
If I get any good photos, or a walkthrough, I'll post it up here.
