Old 07-03-2019, 08:51 AM   #1
Bob Q
A/C Condesner and replacement
I’m getting ready to replace the A/C condenser and other A/C components on my dad’s ‘84 K2500 with a 6.2L and will be converting it to R134 at the same time. In regard to the parallel flow condensers, is there a particular one or brand that has shown to fit or perform better? Or would a replacement from Napa or other parts stores be ok? I tried getting the Delco 15-6960, but it appears to be no longer available and I’ve read that others found the dimensions aren’t the same as the stock unit. Thanks!
Bob Q.
'83 K2500 6.2L
Bob Q is offline   Reply With Quote
Old 07-03-2019, 04:16 PM   #2
Jeepwm69
Re: A/C Condesner and replacement
Watching to see what is recommended. Something I'll need to do at some point.
Jeepwm69 is offline   Reply With Quote
Old 07-03-2019, 04:48 PM   #3
I am still using my original one that came with the 81. When I put in my new compressor, I upgraded all the under hood stuff but that. It works fine, but I am told it would be better with a newer style. As far as brand I got a set off ebay. To me if you are getting everything, you may want to look for a package set designed to work with one another. I do not know much about the brand and all but I have heard the "4seasons" name mentioned by many of my friends.
Old 07-04-2019, 12:17 AM   #4
Bob Q
The original unit in the truck has been open to the atmosphere for some time now, so that’s one of the main reasons I want to replace it. I wasn’t sure if there was a particular condenser that others have found that fit and perform better than others.
Bob Q.
'83 K2500 6.2L
