Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WTB Parts
Old 09-03-2019, 04:07 PM   #1
RThree
RThree's Avatar
WTB 1969 C10 RWD RH side (driver's) exhaust manifold for 307
I'm looking for an exhaust manifold to replace my driver's side exhaust. I recently purchased a truck that was driven (probably for years) with a closed/malfunctioning manifold heat riser. The exhaust burned a hole through the side of the manifold. So, I need a new one. I've got a 1969 RWD Chevrolet C10 with a 307 all stock.
- 1972 K20 Longhorn, 4wd conversion. "TAWNKAA" Project. 292ci Inline 6 / '93 NV4500 / 32 spline 205 TC / Dana 60s front & back / rear Detroit Locker / 4.10 Gears / 35" BFG MT KM2 / 4" Tuff Country lift. "TAWNKAA"Build Thread http://67-72chevytrucks.com/vboard/s....php?p=6823933
- 1970 C10 Lonbed, 292ci Inline 6, 3 on the tree, stock.
RThree is offline   Reply With Quote
Old 09-15-2019, 08:37 AM   #2
68 TT
Still plays with trucks
68 TT's Avatar
Re: WTB 1969 C10 RWD RH side (driver's) exhaust manifold for 307
Is this what you were looking for?
It has both a functional heat riser assembly and a heat riser with the core removed and holes pipe plugged. Run with whatever you choose.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 09-16-2019, 07:27 PM   #3
RThree
RThree's Avatar
That is what I was looking for. I actually found one though. Thanks for the reply!
Old 09-17-2019, 07:34 AM   #4
68 TT
68 TT's Avatar
Glad you found what you needed.
