09-29-2019, 11:53 AM | #1 |
Quick, dumb EFI Fuel Filter question
OK, I am going to run my fuel lines for my system today (hopefully). I am using FiTech EFI system with an in tank fuel pump...so I will have a return line. I have the fitech fuel filter.
I know in a conventional carb setup it is close to the carb...I can't find anything for an in-tank pump setup for the Fitech...only with an inline pump or their command center. My question is... Does it matter where in the fuel line it is? Do I put it close to the gas tank or in the engine bay? Or anywhere that is convenient? Last edited by roll_the_dice; 09-29-2019 at 02:41 PM. |
09-29-2019, 01:36 PM | #2 |
Re: Quick, dumb EFI Fuel Filter question
In a convenient location away from exhaust
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
09-29-2019, 02:16 PM | #3 |
On the frame would work.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
09-29-2019, 03:29 PM | #4 |
I too will be running some fuel lines for an in tank pump. From what I've read, you can put it anywhere in the supply line you want. As someone said, keep it away from heat and also moving parts.
09-29-2019, 03:49 PM | #5 | |
I think I will tuck it on the frame under the drivers side door. Fairly easy to get to if I need to or when I have to replace it. |
09-30-2019, 05:58 PM | #6 |
1965 Chevy C10, 2005 4.8L/4l60
I ran mine for my LS from tank, inside the driver side frame rail and then across the trans crossmember, then up the trans to the motor.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
10-01-2019, 09:29 AM | #7 | |
Sounds like a good way to run it...I started mine yesterday down the drivers side frame in the engine bay and up to the EFI... I tucked the filter in the frame right where the bed starts behind the cab...should be an easy location to get to if need be. |
