Old 10-06-2019, 12:36 PM   #1
CJ2A
CJ2A's Avatar
How to mount ECM
I am at a point where I need to mount the ECM in this 1963 GMC. My LS1, computer, wire harness, and gas pedal are out of a 2005 Chevy pickup.
Can anyone send photos of where to mount the stock computer for an
LS1 swap ? I am looking for the best location everyone else may have found by trial and error
How about photos of how to mount the fire by wire pedal ?
Where did you have the wiring harness penetrate into the cab ?
CJ2A is offline   Reply With Quote
Old 10-06-2019, 09:24 PM   #2
nsb29
nsb29's Avatar
Re: How to mount ECM
You need to go to engine and drivelines then click on LS swap. I put mine under the seat, some people put it on the inside of the firewall others put it on and inner fender
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 10-07-2019, 09:32 AM   #3
88Stanger
88Stanger's Avatar
In my "69 I put it under the radio on the floor, then made a small console to cover it.
88Stanger is offline   Reply With Quote
Old 10-07-2019, 11:09 AM   #4
loosenutz
It can go pretty much anywhere you want. The problem with a lot of the truck engine harnesses though is that they are pretty short. You probably won't be able to get it inside the cab without extending the wires. I plan to put mine on the firewall. Really no reason not to, except for cosmetics.
loosenutz is offline   Reply With Quote
Old 10-07-2019, 01:35 PM   #5
mongocanfly
Post Whore
mongocanfly's Avatar
Under seat if possible....behind dash is 2nd option
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 10-08-2019, 11:38 PM   #6
truckdude239
truckdude239's Avatar
The computer mount off an 2003 s10 zr2 also fits out computer nice and has hole for 3 bolts
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 10-12-2019, 01:46 PM   #7
bigmoe
bigmoe's Avatar
My reworked stock wiring harness (Gen IV 5.3L) is too short for anywhere but on the driver side inner fender of my 65 C10. I plan to try to run my air intake to the drivers side and I'm thinking that the air filter will cover it a bit so it's less noticeable. At least the Gen IV ECM is smaller in size.
bigmoe is offline   Reply With Quote
Old 10-13-2019, 10:56 AM   #8
Gregski
Post Whore
Gregski's Avatar
this is on my square but I re routed all the wires, shortened them, re pinned them, and kept the PCM in the engine compartment on the driver side inner fender, you can also see my DIY fuse block behind it on the firewall - if I recall correctly the injectors have the shortest wires so they will dictate the final resting place of the PCM but no wires needed lengthening - I did buy some proper tools to help unpinning and crimping the PCM connectors
Gregski is offline   Reply With Quote
Old 10-16-2019, 05:39 PM   #9
First c10
First c10's Avatar
Post 787.
I kept mine in the engine bay behind the driver headlight area. I moved the horns to the passenger side.
http://67-72chevytrucks.com/vboard/s...659275&page=32
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 10-21-2019, 12:41 PM   #10
Flubyu
I had my truck harness lengthened to allow me to put the PCM under the seat. As for the pedal mounting, I would HIGHLY recommend buying the pedal bracket that a fellow member here sells in the LSX classifieds. Top notch.
'71 C-10 SWB Shop Truck
Currently 350/350, soon to be LS'd.
Flubyu is offline   Reply With Quote
Old 10-21-2019, 12:41 PM   #11
Flubyu
http://67-72chevytrucks.com/vboard/s...d.php?t=651123
