Old 10-07-2019, 09:19 AM   #1
verdell
verdell's Avatar
60-63 Vintage Air
For the guys that have installed VA in a '60-63 (and maybe '64-66) how did you route the hose duct from the Evaporator unit over to the far drivers side?? Over the top of the steering column? Any pics would be helpful..
verdell is offline   Reply With Quote
Old 10-07-2019, 10:12 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: 60-63 Vintage Air
While my engine choice is a little unique, this is how I routed my hoses:
http://67-72chevytrucks.com/vboard/s...&postcount=251
The evaporator kit calls for using the hardlines routed under the battery tray, but I wanted to route it to the outside of the battery tray area since I mounted my ignition unit and other components in that area.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 10-07-2019, 12:40 PM   #3
verdell
verdell's Avatar
Vin,
Apologies if I wasn’t clear but I’m referring to the duct hose inside the cab. On
the driver’s side specifically. Thanks for the response though..
Old 10-07-2019, 04:32 PM   #4
forestb
forestb's Avatar
The guys that installed mine route it up and over the column
forestb is offline   Reply With Quote
Old 10-07-2019, 11:03 PM   #5
AcampoDave
AcampoDave's Avatar
Yep, up and over is what I did too
AcampoDave is offline   Reply With Quote
