10-17-2019, 02:30 AM | #1 |
Grounding My Gas Tank?
I Made an Aluminum Gas Tank For My 69 C10.
Just Wondering How I Should Go About Grounding The Tank and Sending Unit. Going To Use Rubber pads Between The Tank and Frame.. Anything Else I Should Take Into Consideration Thank You Posted via Mobile Device |
10-17-2019, 09:22 AM | #2 | |
The Older Generation
Re: Grounding My Gas Tank?
I would just run a ground wire from where the mounting bolt contacts the tank flange to the frame. The sender should ground fine through the mounting bolts or twist lock. The tank might or might not ground through the mounting bolts, depends on how clean the frame is at that point. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 10-17-2019 at 11:40 AM. |
10-17-2019, 10:04 AM | #3 | |
10-17-2019, 06:00 PM | #4 |
Old member
Agree take a couple of good size wire and make some ground straps and hook one on each side of the frame to one of the mounting bolts to the tank. Never can have to many grounds!
Thread Tools | |
Display Modes | |
