Gen 3 or gen 4
Just wondering what your thoughts are on these engines? Are the gen 4’s as good or better than the gen 3’s?
I personally went with a gen 3 because of the price and dbc. I also heard around 2007 thru 2014 gm was not doing well financially and so maybe I should stay away from those years. |
Re: Gen 3 or gen 4
If you're dropping in an engine/transmission combo and are not concerned with cruise control, go with gen 4. If you're bolting up a manual or older automatic, or want integrated cruise, go with gen 3.
I'm not following any of that. I'm slogging through a gen 4 swap. I'll need to use the body control module for the cruise interface, and I'm hoping my manual swap will work out okay. There's some hope of using the instrument cluster as a "black box" to provide cruise and battery lights on my '87 dash. We'll see.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
![]() Join Date: Aug 2018
Re: Gen 3 or gen 4
Gen 3's are easier to find and cheaper and easier to tune. Also no AFM to deal with. That being said, a lot of the Gen 4's are aluminum blocks so you get a weight savings. Gen 4's also have a nice small PCM, so no big bulky computer and TAC module like a Gen 3. We put a Gen 4 5.3 in my dad's 64 and it was pretty easy. We're putting a Gen 3 6.0 in my 68 and it's not hard either.
Overall, I think the Gen 3's are more user-friendly and are my preference. As far as DBC and DBW, I think it's more user-preference. DBC can be hooked up to your stock linkage and throttle pedal setup and gives you a better "feel" whereas DBW requires a throttle pedal swap.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
Re: Gen 3 or gen 4
Just got my Gen3 5.3/4L80E combo road worthy. The motors are solid, no variable displacement non-sense, wiring is super easy, powers, grounds and interface to the interior. I went with DBW and my only complaint is the height of the pedal from the floor. Its not bad but its not factory by any means. Otherwise Gen3 is probably as easy it gets.
Paul
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!! ![]() My Build Thread: Project 72' Green http://67-72chevytrucks.com/vboard/s...d.php?t=587932 |
Re: Gen 3 or gen 4
Thanks for the replies.
