Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 11-14-2019, 07:40 PM   #1
Andy4639
Old member
Andy4639's Avatar
Talking Learning to weld all over...
I've welded on golf carts most of my life but this dang sheet metal is tough! It's not forgiving either.
I'm getting better as I go but man you have to be careful are you blow a hole right through it.
I spoted in a piece on the inside and then cut another to sit flush with the outside and tacked it into place. I think it came out OK for never doing it before.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-14-2019, 09:42 PM   #2
hugger6933
Re: Learning to weld all over...
Andy what size wire are you using? A .023-.025 will make such a huge difference between the normal .030-.035 that most welders normally are set up with. I was so bad wanting to put a v-twin in my gas ezgo but sold the cart and then somebody stole my vtwin . Still think of it now and then. Jim
hugger6933 is offline   Reply With Quote
Old 11-14-2019, 10:01 PM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: Learning to weld all over...
Not sure what size the wire is. I'm using the welder at my friends shop. I haven't even looked. I bought a gas bottle for it and he said use it up. I'm trying to!
I got a smok'in deal on mine if you want it. V twin built to the top of the line parts. 6500 RPM all day long. It's a nice ride. It will pick those 27" front tires off the ground if you want it to.
Old 11-14-2019, 10:49 PM   #4
Custom 68
Custom 68's Avatar
You need to make sure it's set up to use the gas. If he wasn't using gas before it may be Flux core wire and the polarity is wrong. The pics don't look like Flux core so I'm guessing it's right.
Good luck and keep going it's looking good
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 11-14-2019, 11:38 PM   #5
franken
Purists wouldn't have used a backing bit of steel but carefully fit the patch and butt welded.
I'm no great welder to have an opinion, but yours look welds look good.
franken is offline   Reply With Quote
Old 11-14-2019, 11:57 PM   #6
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Learning to weld all over...
Dave it is. I filled his bottle for him since I'm using it.
Old 11-14-2019, 11:59 PM   #7
Andy4639
Old member
Andy4639's Avatar
That is what I did. I tacked the first insert to the inside of the cab. Then cut another to lay inside the opening and tacked it into place.
Old 11-15-2019, 08:10 AM   #8
mongocanfly
Post Whore
mongocanfly's Avatar
Andy...you never want to double up on metal like you did..your inviting a place for water ..then rust..plus the double thickness of metal will cause more stress...
cut your patch to fit the hole with very little gap...i like a gap because the weld seems to penetrate a little better...get your self some copper to use for a backer..youll be amazed at how good it works...with the copper you can run the heat a little higher and have a flatter weld thatll need less grinding
ive used some of those welding magnets and panel clamps from eastwood to hold my patchs in place
also like stated above use a .023 ez grind wire...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 11-15-2019, 07:48 PM   #9
Jrainman
Jrainman's Avatar
Thats all good advice rite there , just make sure if you do have to change over to .023 wire you check your wire feed Roll and make sure to use the rite groove in the feed roll for the gauge wire you set up in the welder , the roll is usualy marked for what gauge each groove will handle.
Jrainman is offline   Reply With Quote
Old 11-15-2019, 10:55 PM   #10
Andy4639
Old member
Andy4639's Avatar
I guess I could grind the inside piece out and it should be OK right. I just put enough tacks to hold it in place.
The hard part will be getting the grinder in there.
Old 11-16-2019, 10:43 PM   #11
hugger6933
On top of changing the feed roller to the right size don't forget to change the nozzle on the welder to correspond with the wire I'm sorry I did'nt tell you all that in my first post.
Old 11-22-2019, 11:32 PM   #12
davischevy
davischevy's Avatar
Andy, you are a braver man than me. My welds are so bad, no way would I take a picture of them.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 11-22-2019, 11:58 PM   #13
Andy4639
Old member
Andy4639's Avatar
A grinder does wonders!
I had my buddy who is retired welder instructor come over and set the machine up for me. We then welded up the passenger side rocker and cab corner. Not bad at all once he got the machine right. The door lines up almost perfect. I'm just a tad off at the back but for the first time I take it.
Drivers side may be a different story though.
Old 11-23-2019, 11:17 AM   #14
wixthedog
wixthedog's Avatar
I've seen much worse! I've always enjoying working with metal much more than wood, I find it easier to fix mistakes and save yourself.
Keep it up!
Mike
1976 C10 RCLB - 350 - SM465 4 Spd - 4.5"/6" Drop
Obligatory Build Thread HERE!
1979 C20 RCLB - 350 - TH350 Auto
wixthedog is offline   Reply With Quote
Old 11-23-2019, 06:47 PM   #15
nsb29
nsb29's Avatar
Looks like sum one was bound and determined to have speakers in the door
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 11-25-2019, 08:29 PM   #16
Andy4639
Old member
Andy4639's Avatar
Yea at some point that hole will be filled up to!
It did help to get all the window stuff out of the door though!
