4 link and anti sway bar
installing a triangulated four link, would a rear sway bar be beneficial?
51 chevy truck, 2” drop spindle mustang 2 front, like this? ![]() Last edited by skip99; 11-16-2019 at 10:43 AM. |
![]() ![]() Join Date: Oct 2014
Re: 4 link and anti sway bar
Yes
4 links benefit more then leafs when the sway bar is added. By design they are supposed to have more movement.
Even just a small 3/4" one will make the truck feel more road stable. How big you go is dependent on the total concept of your truck. Depending on how much travel you need such as if you intend to lay out your truck. Longer away bar arms plus links maybe nessacary to accommodate the travel. The tube sway bars they sell kits for are a great source of parts to do a custom set ups since the system is modular. You have a lot of widths to use, and different arms you can use. Plus some arms can be bent for needed further customization. |
#4 | |
