11-23-2019, 01:37 PM | #1 |
Help identify posi
I just pulled this from my 72 c10 and was wondering if anyone can identify what brand it is ?
11-23-2019, 01:49 PM | #2 |
Re: Help identify posi
rpo code - g80 = gov-loc . 10 and 12 bolt rear versions are kind of weak . the 14ff rear version much better .
if you know there there and how they work there fine . but for people beating on them and or hard / soft surface mix each tire and hit gas they can go BOOM / aka gov-bom nickname. its a open diff until the 1 wheel spins faster than the specific rpm difference and then the fly weight swings in and locks the clutches up .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
11-23-2019, 01:54 PM | #3 |
Thanks for the quick response, Glad I did a gear and Truetrac swap.
11-23-2019, 02:42 PM | #4 |
Post Whore
I thought govlock started in 73....right or wrong?
You did good with trutrac...
11-23-2019, 05:13 PM | #5 |
I'm not sure what year they started, but my 72 had one that was original... until it exploded through the pumpkin.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
11-23-2019, 05:30 PM | #6 |
Post Whore
Ok..thanks....I thought I read somewhere that it came about in 73
11-23-2019, 08:09 PM | #7 | |
edit: not the truck in my sig. That has a gov loc know (14 bolt)
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
11-23-2019, 08:27 PM | #8 |
They did come out in 73. So it may have been transplanted some time in the trucks 48 years of mods.
Gov-lock is GM's name for the differential. G80 is the RPO code used by GM to identify the option. Its was introduced by GM in the newly redesigned 1973 trucks as the G86 option, an upgrade from the G80 which was a clutch type limited slip also known as Positraction. Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
11-23-2019, 09:52 PM | #9 |
I guess I can't say for sure. I didn't get it until 2007, so anything is possible. It was definitely the factory 12-bolt housing, though.
I never knew a differential could come apart in so many pieces. It was fragmented like a grenade.
