Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 11-26-2019, 01:55 PM   #1
awbrown
2011 silverado issues 6.0 LS
I bought this struck from an auction and other than this one issue It runs and drives like new ... It sets a code saying the engine is lean ..I have had the shop next to mine (I have a machine shop , he is a repair shop ) look at it a few times and it still sets the code ... I can feel a miss or hitch in the engine as I roll into the throttle to increase speed .. It runs fine cruising and if I am hard on the gas .. Anyone had this issue , or have experience with this problem?
Thanks in advance .....
awbrown is offline   Reply With Quote
Old 11-26-2019, 04:08 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: 2011 silverado issues 6.0 LS
I have a 2006 K2500 with a 6.0L and it started to act up like that recently but it set no code. Then one day shortly after on the highway it lost power and was running rough as all get out. I moved over to the shoulder and it died before i rolled to a stop. I sat there for about 15 minutes trying to figure out what just happened. Then tried to start it and it fired right up, but with a check engine light on. I limped it to an Autozone (would run for a bit, then run rough and die), where they put a scan-tool on it. P0336 Crank Position Sensor.
Replaced it with a new one the next day and runs like a top again.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 11-29-2019, 09:42 PM   #3
awbrown
2011 Silverado 2500hd setting lean code
I bought this truck from an auction and other than this one issue It runs and drives like new ... It sets a code saying the engine is lean ..I have had the shop next to mine (I have a machine shop , he is a repair shop ) look at it a few times and it still sets the code ... I can feel a miss or hitch in the engine as I roll into the throttle to increase speed .. It runs fine cruising and if I am hard on the gas .. Anyone had this issue , or have experience with this problem?
Old 11-30-2019, 09:22 AM   #4
Re: 2011 Silverado 2500hd setting lean code
What is the code? Sounds like it might be one of the O2 sensors. If you haven't you can try cleaning out the MAF and check for a vacumn leak. That is all that pops into my head right now.
Old 11-30-2019, 09:02 PM   #5
95 S_Trucker
95 S_Trucker's Avatar
Reported Post by 95 S_Trucker - Forum: Engine & Drivetrain - Reported User: awbrown
95 S_Trucker has reported a post.
Reason:
Duplicate thread on same topic
http://67-72chevytrucks.com/vboard/s...75#post8635075
Post: 2011 silverado issues 6.0 LS
Assigned Moderators: truckdude239
Posted by: awbrown
Original Content:
95 S_Trucker is offline   Reply With Quote
