12-02-2019, 04:36 PM | #1 |
Tightening up a tilt column. Is it DYI?
My tilt column is kinda loose . Everything works fine, but I’d like it to not have the play in it.
I’ve seen a couple YouTube videos on columns for Square body trucks but not ours. I consider myself pretty good at fixing things myself (as I’ve done all the rebuilding of my truck), but don’t need to tear it down, before I find out it can’t be done without specialty tools. As I said I can do things myself, and don’t really want to spend $500+ to have a vendor do what I can myself.. Feel free to give whatever input you can, from advice to “I wouldn’t try that if I were you”. |
12-03-2019, 12:21 PM | #2 |
Re: Tightening up a tilt column. Is it DYI?
I see a lot of lookers, but I guess nobody’s gonna respond.
12-03-2019, 12:26 PM | #3 |
Its been a long time since I worked on one, but there are 3 nuts in there that loosen up & cause the bowl to be loose. If those are tightened up it takes the play out of it. I just can't recall how I got to them.
George |
12-03-2019, 12:43 PM | #4 |
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
12-03-2019, 01:54 PM | #5 |
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
12-03-2019, 02:15 PM | #6 |
I've rebuilt 3 tilts using the info in these 2 threads. The toughest part for me was pulling the collar without damaging it.
http://67-72chevytrucks.com/vboard/s...d.php?t=157328 http://67-72chevytrucks.com/vboard/s...d.php?t=329008 Edit: Here are pictures of the tools used. The first is a homemade puller for the collar. The second is the pin puller. I bought the tool in the third picture after I refurbished the columns. I think it is used to remove the shift tube (see pictures in the 2 links). Last edited by FirstOwner69; 12-04-2019 at 04:47 PM. |
12-04-2019, 10:06 AM | #7 |
Yes you can do it. The collar is the worst part. I soak the collar with Kroil for a week before I even attempt to remove it. It’s steel and slip fits onto the column, so any light corrosion makes it super tight and easy to damage.
Here’s a picture of the puller I modified for the collars. I used a cut off wheel to slot the jaws so the fit in the rolled edge of the collar.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ Last edited by clay68c10; 12-04-2019 at 10:33 AM. |
12-04-2019, 01:29 PM | #8 |
Wow. Great responses.
So, say I can find the two specialty tools (I have a puller i can use), is this doable? As I said before, I can fix most anything, but I don’t want to get into something too deep, and end up ruining my column. Thanks again for the responses |
12-04-2019, 01:36 PM | #9 |
Wow
I finally had time to look at the other links. Now I’m kinda leery of tearing into this. What is it that causes the “play” in the column? Is it the pivoting knuckle? Or are there screws that can be tightened? |
12-04-2019, 02:27 PM | #10 |
i would recommend you contact member Kevsclassic he refurbishes columns , he might be able to assist or redo yours.
I bought a gm tilt from him and I have no complaints
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
12-04-2019, 04:39 PM | #11 | |
12-04-2019, 04:52 PM | #12 |
It's the 4 bolts that hold the knuckle to the column. They get slightly loose and you feel that slack magnified by the distance to the outer edge of the wheel.
I have a couple of pics
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ Last edited by clay68c10; 12-04-2019 at 04:59 PM. |
12-04-2019, 05:06 PM | #13 |
Loc-tite on those bolts will cure it.
While the knuckle is out, clean/lube as needed and put it back in. It will only go in one way. You will need to fiddle with it to get it just right so the bolts will start. I run the bolts in dry to get it all centered up and then take them back out one at a time and loc-tite them individually. A hint; take the upper half of the knuckle out with the steering shaft attached. If the bearings feel bad, then you can opt to take them apart and clean/lube them on the bench as a separate unit. Also, use a wire wheel on a drill/die grinder to clean up the steering shaft end so the lower bearing will slide out easier. Take it down to shiny metal. Any rust or paint will make it very hard to get that bearing to slide off. Add some spray lube to help. The ID of the bearing has an o-ring to allow the shaft to move slightly as the tilt is operated.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ Last edited by clay68c10; 12-04-2019 at 05:13 PM. |
12-04-2019, 05:34 PM | #14 |
I did it on a 1973 trans am back in 1980 before the internet! With all the information out there now, you can do it.
Good luck, Rg
12-04-2019, 11:39 PM | #15 |
Ok, y’all are convincing me that this is something I can handle.
Can it be done in the the truck, or should I pull the column out, and do the work on the bench? |
12-04-2019, 11:45 PM | #16 |
I'd pull it. It'll make it a lot easier for a complete go through. However, you may be able to get to those screws while the column is installed.
12-06-2019, 03:44 PM | #17 |
I agree, easier to pull it.
12-07-2019, 12:03 AM | #18 |
Again thanks a million for all the input.
I’m going to pull it this winter. I’m gonna fix the shift lever spring, and turn signal canceling cam while I’m at it. |
12-08-2019, 02:30 AM | #19 |
Good call, you’ll like having it all work correctly.
If you have any problems, shoot me a PM and I’ll try to help you out
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
12-08-2019, 12:23 PM | #20 | |
I’m finishing my new house then have to move my stuff from SC, before I can even think of getting into this. |
