Old 12-14-2019, 02:20 PM   #1
ibinyth
18x12 backspacing question
Can I run a 18x12 with a 6" backspacing on a late model 70 c10 wider rear end? Truck has no bedfloor or tubs, just bedsides. How close would that get it to flush?
ibinyth is offline   Reply With Quote
Old 12-15-2019, 05:08 AM   #2
ibinyth
Re: 18x12 backspacing question
They also come in 5.5bs
Alternative is 18x11 with either 6bs or 5bs
Old 12-16-2019, 07:56 AM   #3
PGSigns
PGSigns's Avatar
You would need to pick the tire you want to run and use a tool like the ones listed in the link below. The tire is what you have to make fit and the tool will tell you the rim you need.
Jimmy
https://www.summitracing.com/search/...imulator-tools
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-16-2019, 11:04 AM   #4
SCOTI
SCOTI's Avatar
The shorter width 6-lug 12bolts allow about ~10" of back space before you have clearance problems (if the wheel diameter clears) @ the suspension. I ran 15x14" wheels (9.75"BS??) w/widened tubs & the shorter width 12bolt
So, will your proposed combo's 'fit' with the wider housing? They can. Will they look right? Only way to know is to measure your set-up. I would bet if the truck is lower than stock height, there will be issues @ the bedside requiring more back spacing. My best WAG is you need closer to ~8" BS w/the wider rear housing if the truck is lowered & you don't want to have to worry about rubbing @ the bedside.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-17-2019, 05:21 PM   #5
68Stepbed
68Stepbed's Avatar
What wheels are you looking at?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
backspacing, wheels
