01-01-2020, 06:41 PM | #1 |
HEI Ionizing Issue
So I have read about this in the past. About every 3,000 to 5,000 miles I will have to pull my HEI cap and clean it out due to some type of corrosion buildup on the brass tabs for the plugs. Also some build up on the rotor yet minimal.
I read somewhere that it is Ionizing Air in the cap that causes this. I will run rough upon cold start up until fully warm. Slowly causes a loss of mileage and power. I have to scrap, sand it off and spray out the cap with carb clean and re-assemble. Is there a way to prevent this from happening? Remember hearing about some drilling a hole in the cap yet this will let ambient moisture in most likely causing more issues. Would love to hear the cause and or any mods that can be done to prevent this from occurring. |
01-01-2020, 09:08 PM | #2 |
Re: HEI Ionizing Issue
Is there a chance you have an incorrect rotor causing a large arc? I ran one for years without any problems
01-01-2020, 09:47 PM | #3 |
Well I hope not, the rotor always comes with the cap. These are the MSD units.
Found this on Crankshaft Coalition: Plug gap Don't be tempted to excessively widen the gap. The correct gap is 0.035"- 0.040" for the majority of cases. Using plug gaps wider than that is unnecessary when using a basically stock HEI ignition. Wider plug gaps (or faulty ignition wires) cause voltage spikes in order for a spark to occur. This in turn causes the cap to fill with ionized air, and this can cause erosion/degradation to the components along with spark scatter and/or voltage bypassing to the distributor advance mechanism, shaft, etc. It is hard on the secondary ignition components in general and just isn't needed in the vast majority of cases. The large diameter of the cap helps to prevent this and it works well enough in a passenger car, even with the wider gaps that were used for some applications. But once the RPM goes up and the cylinder pressure increases, the chance of a misfire increases dramatically with a wider plug gap. My plug gap has always been .045. No misfires attributed to Carb or Distributor, Timing. I know GM tried numerous plug styles with gaps as large as .060 so the above is just the opinion of the writer which is not bad advise. Last edited by toolboxchev; 01-01-2020 at 09:55 PM. |
01-11-2020, 02:52 AM | #4 |
So, are you going to clean it up and try plug gaps of 0.035"- 0.040" and see if the problem goes away? It will be interesting to hear back from you if that fixes it.
01-11-2020, 08:34 PM | #5 |
Yea that is what the plan is, as soon as it stops raining. Fighting another issue right at the moment and waiting for some parts from MSD. Those techs are a wealth of knowledge.
I did clean it up and its running, did not re gap the plugs, yet. I am a lazy turd sometimes! Found out also, no matter the coil nor module I would need a 6AL box to get anything to reliably jump a gap bigger than .040. That would be coming from the MSD techs. |
01-11-2020, 08:45 PM | #6 |
Are you interested in a gap bigger than .040?
01-13-2020, 01:08 AM | #7 |
Yes I was, this has been going on for a long time. Was using Accel Super Coil with Accel module. Supposed to get more voltage to the plug to jump that gap.
Apparently this is not true. It just makes the spark more difficult to jump that gap. Well at least that is what they are teaching me in theory. |
01-13-2020, 10:23 AM | #8 |
I don't like spending extra money on vehicles when I don't have to and have always considered these fancy ignition components in that category. Original HEI is good enough for me and I will put up with replacing an occasional module or pick up coil. Granted, I no longer like playing with points and would look for alternatives to that system.
If you are talking computer controlled and rev limited distributors, that stuff is way over my head. It does seem that one or more of your components is not matched correctly to get the job done that it has to do. Last edited by vince1; 01-13-2020 at 10:31 AM. |
01-13-2020, 12:21 PM | #9 |
80's Dodge 2.2/2.5 engines used a vented distributor cap.
https://www.rockauto.com/en/moreinfo...=2242&jsn=2242 If your wondering about the contacts on the cap, the plug wires push through. https://www.rockauto.com/en/moreinfo...89266&jsn=2264
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
01-13-2020, 12:42 PM | #10 |
Right now, am not looking to vent, MSD techs say yea sure drill a hole in it, but then you have another problem.
Would be great to find a cap with brass terminals and factory vent. Interesting thought on those plug wires. |
01-13-2020, 12:48 PM | #11 |
01-14-2020, 11:46 PM | #12 |
Why not just set the gap at .035 and put a new distributor cap on there and see if it solves the problem? Is there an actual advantage to wider gap?
01-15-2020, 03:11 AM | #13 | |
OP didn't say what he was running though. -BA
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
01-15-2020, 12:35 PM | #14 |
I just read somewhere and can,t remember where but they said to go to .40 gap to fix this
01-25-2020, 02:05 AM | #15 | |
Post more tomorrow. |
02-17-2020, 11:53 PM | #16 |
Was a gmc dealer mechanic in the late 80's till 96. Gm had hole(s) in the distributor base with screens over them during this time. 1987 was first year for efi and last year for that body style. 1988 and newer was same efi but different body. Always noticed nice terminals inside the 87 body style and crappy terminals around 50k in the 88 and newer.
Same distributor even down to housing number. i suspected the older style caused more airflow in the distributor area. Anytime you have a spark in a confined area the ozone that is created becomes corrosive! Remember how fresh the air smells after a thunderstorm?? |
02-18-2020, 03:20 PM | #17 |
I'm currently installing an Edelbrock Pro-flo 4. The distributor sure looks like it's an MSD. It has a factory vent.
Regarding plug gap, the Vortec heads spec a .60 gap. The set of AC Delco plugs I just bought were pre-gapped. They varied between .053 and .062. I set them all at .055. |
