01-13-2020, 06:54 PM | #1 |
Clark 5 speed Trans OD
Does the Modle number on this tag mean this trans is OD
01-13-2020, 08:20 PM | #2 |
Re: Clark 5 speed Trans OD
Not sure, but do you know the Shift Pattern?
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan |
01-14-2020, 03:25 PM | #3 |
01-14-2020, 03:40 PM | #4 |
Not familiar with that one.
The Clark in my '62 was: 2 4 R --N-- 3 5 1 It was not an OD. Along with a 2-Speed Rear, the Shifting Sequence was: 1L 1H 2L 2H 3L 3H 4L 5L 4H 5H But, the Trans in my '67 was like your picture above, but I never knew what kind of Trans it was. Had the same Shifting Sequence though, and was also not an OD. Could have been a Clark, possibly.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan Last edited by C10 - C90 Bill; 01-14-2020 at 03:52 PM. |
01-14-2020, 05:05 PM | #5 |
From what I understand about those, that's a direct 5 speed, no OD. I think the OD models were denoted with a "VO"
I'm sort of hunting for a Clark 5 like that one, I need a gear that's slightly underdriven in my truck but not as deep as 3rd is on my Muncie |
01-14-2020, 08:03 PM | #6 |
I agree VO would be an overdrive. What I like most about the truck OD's, is the .80 range overdrive, instead of the typical light duty pickup OD's in the .70 range.
01-15-2020, 12:42 AM | #7 |
Thanks you all for your reply
01-16-2020, 03:48 PM | #8 |
The Clark transmission model you should be looking for is a 280ovo. There was a article about this swap into a square PU several years ago, I think the article was in 4 wheel and Off Road but I don't remember for sure
01-16-2020, 04:16 PM | #9 |
Not a clark, but here is a medium duty overdrive transmission that would be easy to swap if you dont need PTO...https://www.fourwheeler.com/how-to/t...-transmission/
They have pto's out there but theyre costly. |
01-17-2020, 10:27 PM | #10 |
https://www.chevyc60.com/the_transmission_page.htm
After looking at your shift pattern I don't believe it's any of those either |
01-18-2020, 01:10 PM | #11 |
That's the shift pattern on the five speed that was in IH Loadstar trucks and busses, FWIW.
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
