Old 01-22-2020, 03:58 PM   #1
G-NUT
G-NUT's Avatar
how to plumb GM hydroboost to a rack and pinion
I have a '84 burb with stock hydroboost. Years ago the diesel motor was swapped to a 350. I am changing out the front suspension to a PBFab or Porterbuilt system. Can you plumb this hydroboost to a power rack and pinion steering rack? If so, what's the correct connection?
Thanks.
'84 Suburban C10 Silverado - laying pinchweld to the ground on 22/24.
/Porterbuilt / Accuair / Bonspeed / Landsail / Auburn Gear / Richmond Gear / Moser / Raybestos / ProMaxx / Edlebrock / Street Demon / Taylor Wire / K&N / MSD / KillMat /
SOLD: 1985 GMC Sierra Classic 2500 3+3 Crew Cab Long Bed
G-NUT is offline   Reply With Quote
Old 01-22-2020, 04:13 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: how to plumb GM hydroboost to a rack and pinion
Yep..hydroboost will work with r&p..hook it up just like the r&p was the old steering box...
I'm not sure what rack your using but the pressure line from the hydro will go to pressure side of the rack..other side of rack goes to reservoir...and if you dont have one now would be a good time to add a inline cooler..I'm sure youll need custom lines as well...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-22-2020, 04:23 PM   #3
G-NUT
G-NUT's Avatar
Thanks for the info and quick response. I've tried a few short-timed searches and came up short.
The rack & pinion came from CPP when I ordered my Porterbuilt front kit in 2014. Looong story on why I'm just getting to the point for installation but here I am. Not sure of the vendor but I believe it's a Mustang II r&P.
They sent me a few custom hoses. That's when they thought I had a standard power steering pump setup (which at the time I did, it was going to go on a '85 truck I had). Maybe I can get something to work. If not I'll measure and get some custom hoses.
Old 01-22-2020, 04:44 PM   #4
mongocanfly
Post Whore
I've got some info for hydroboost and rack steering on computer at work..I'll add later
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 01-22-2020, 04:54 PM   #5
G-NUT
G-NUT's Avatar
Thanks a lot. I will gladly take all the info I can get before I begin installing. I'm hoping to be to that point in a week or so. Having to work on it outside (a bit cold), and when I have time. Family first.
Old 01-22-2020, 08:39 PM   #6
mongocanfly
Post Whore
well ..my file got wiped out...I did find these...
https://www.trifive.com/forums/showthread.php?t=67217
https://www.pro-touring.com/threads/...droboost-setup
since its a cpp setup a call to them may be in order..couldn't hurt
Mongo...aka Greg
RIP Dad
RIP Jesse
hydroboost, rack & pinion
