Vision rally wheels
I am looking for some rallies and found some vision rally wheels on ebay. I'm looking to get 15x10 for rear and 15x8 for fronts. My question is the 10's are 4.25 backspace and -32 on offset. Are these going to work and not stick out? I'll be running a 30" tall tire that's 12" wide. I need them to tuck the bed. I dont have a bed on at the moment so I cant really measure and figure I'd ask. Thanks
#2 | |
Re: Vision rally wheels
I have a fleetside, 5/7 drop on stock width rear. I like the rally wheels but being its 6 lug still my options seem pretty limited. Maybe I should hold off till its 5 lug.
#4 | |
My experience says for a 5/7 drop & 10" wheels, you'll prob be looking @ 5-5.5" BS for hassle-free clearance unless the rear end width is different or some other factor is involved. At 5.5" BS, a mini-tub might also be required. While it's possible to get away w/less than 5" BS, you will likely buzz the sidewall on the sheet metal.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-30-2020 at 01:04 PM. |
