![]() Join Date: Oct 2013
Caliper Differences
What are the front caliper differences between those for cars vs trucks, if they both use the same brake pad, pin spacing is the same? The piston diameter is same too. All bolt sizes same.
Inlet brake line location, bleeder, what else? Thanks, Les |
Re: Caliper Differences
Piston size is the main difference. Most "car" calipers only have about 2.5" pistons. Standard caliper piston size for 1/2 ton trucks are 2 15/16" and 3/4 to 1 ton trucks have 3 5/32" pistons.
In fact, the "big bore" caliper is nearly unmatched in clamping force. The only advantage to multi-piston calipers is pressure being applied evenly across the width of the pads vs the center of one pad. Many people think they need expensive brakes to stop a truck, when in fact, upgrading to the big bore calipers and a good set of pads, combined with the proper bore sized master cylinder can bring one of these truck to a halt rather quickly.
Matt,
Thanks for information. Is their a write up on forum on how to add big bore caliper to 72 K10. What rotor ( keep 6 lugs), caliper bracket, caliper, is needed? And what size/diameter wheel do you need to use? Thanks Les Last edited by aotte1; 01-31-2020 at 03:51 PM. |
the 1 ton caliper sounds interesting on a 1/2 ton truck,I would interested as well if they can be made to fit on a 78 style truck
Just order them from the parts store and swap them out. They're a direct swap.
#6 | |
https://www.oreillyauto.com/shop/b/b...=brake+caliper
#7 | |
thanks, finally something easy lol.
![]() Join Date: Mar 2011
Matt, are you saying that the D-52 car caliper, can be replaced with the 1/2 truck caliper with the larger piston...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
It really kinda depends on what year. The reason is rotor thickness. 71-80 1/2 ton rotors are 1.25" thick, and 12" diameter. typical car rotors are 11" diameter and 1" thick. Although the diameter won't affect anything, the rotor thickness creates a fitment issue. However, 81-87 1/2 ton trucks were available in both 1" and "heavy duty" 1.25" rotors. As cheap as calipers are, it's worth a shot to try, but keep in mind the 81-87 calipers are metric, so the banjo fittings are different.
#11 | |
