Cargo light socket connector
Ok
Just received my cargo light but not sure where to find the adapter socket ? I found a socket pig tail 2 wire but not sure it will fit , as a regular 1157 type bulb Won’t |
Re: Cargo light socket connector
This is the pig tail connector I’m talking about .
Old member
This is what you need and you will also need the small switch.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#5 | |
Old member
Old member
A rear tail light pigtail is the same connector by the way.
