12-08-2003, 12:41 AM | #1 |
Trans Cooler Question
Those of you with aftermarket trans coolers, where did you run the lines to get the cooler in front of the radiator. By looking at it, I am guessing I am going to have to drill holes in the core support, or that metal piece between the core support and the front bumper?
Also, when you use the radiator cooler too, which line goes where. Thanks |
12-08-2003, 12:47 AM | #2 |
its all about the +6 inches
If drilling holes in the core is a seriouse issue to you, you could route the lines up and over it. It'll look kinda out of place...but it'll get the job done with no new holes.
Being your location, your best bet would be to route the oil from the rad to the aftermarket cooler, and then back to the tranny. For a truck in cold climates, and that is not driven very far or run very long, (but sometimes worked hard) going to teh aftermarket cooler first may be benificial. In extreem weather locations, too cool of oil can be an issue. |
12-08-2003, 12:50 AM | #3 |
I ran mine under the core suport with hard line.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
12-08-2003, 01:08 AM | #4 |
I think on the 67/68, that area is blocked off with a pan of sorts.
If not, that would be even better than what I said. |
12-08-2003, 01:15 AM | #5 |
Mine is a 70 with AC so its infront of the condensor.
12-08-2003, 01:35 AM | #6 |
Robert Olson Transport
make the holes in the support over is rediculous and lower cna easily be ripped out if you off road or anyting right through the core support is the cleanest look and like lornhorn says you gotta watch the way ya route it in a cold climate
12-08-2003, 01:45 AM | #7 |
Something else to think about, fellow phoenixer, is to mount the cooler somewhers else. I recently put a cooler on a another project under the body with an air scoop, there is plenty of room under the chassis for that. You could also run one from the trans to the radiator cooler then back to a remote mount cooler then into the trans.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
12-08-2003, 01:49 AM | #8 | |
Whick trans line is in and which is out on the radiator? |
12-08-2003, 09:47 AM | #9 |
On mine, I ran the hoses under the core support and tie wrapped them firmly so no dragging or any chance of anything catching them. But I don't offroad either.
In Texas heat, I decided to leave the original hard line coming from the trans to the top hole of the radiator cooler. Then from the bottom hole of the radiator cooler, I ran a rubber hose to the top hole of the aftermarket cooler which I mounted in front of the radiator. The bottom hole of the aftermarket cooler has a rubber line ran to the remaing piece of hard back to the radiator. No problems in 7 years. James |
12-08-2003, 09:50 AM | #10 | |
On the 350 and 700r4 the fluid enters the top and leaves the bottom. Just went throught that for trans cooler install that had a bypass that needed that information. The instruction said to take the lines loose and crank motor to see the oil pushed out the dicharge line. But a little help from friends is a little less messy. Ed ke6bnl So. Calif
Ed ke6bnl Agua Dulce 70 S.E. Los Angeles 70 Chevy short bed 1948 F3 ford pu 1949 F1 stock V8 flathead 3 on floor 1950 F1 pu street rod 1948 F6 Ford Dually/350sbc no bed stock trans&rear 1972 El Camino 4" chop 1953 Chevy 3100 2b daily driver 1970 SB 4X4 400ci 6in lift |
