Old 02-12-2020, 10:30 PM   #1
kipps
Anyone with experience changing a clutch -- 92-95 nv4500?
I'm accumulating the parts and pieces to install a nv4500 with the 92-95 style bellhousing. This has the external slave cylinder, and the internal fork.
The slave cylinder I have in hand has an internal spring, which effectively pushes the throwout bearing into the pressure plate. The spring is relatively weak, but it's enough to hold pressure on that throwout bearing.
Am I missing something here? Is there supposed to be another spring to hold the fork/throwout out of the clutch fingers?
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
