Old 04-02-2020, 06:26 AM   #1
4u2nv
82 rear lower
I bought this truck with a rear lower kit in it and I have it as low as the kit allows , just wondering if this front lowering mount is as low as there is or is there a lower one ????? , just want the rear of this thing about an inch lower
4u2nv is offline   Reply With Quote
Old 04-02-2020, 07:37 PM   #2
PGSigns
PGSigns's Avatar
Re: 82 rear lower
Has it got an axle flip kit in it? If so put a block in it. If not put a flip in it and then adjust the shackle to get it the height you want.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-02-2020, 08:37 PM   #3
4u2nv
Re: 82 rear lower
Jimmy
No flip kit or that would make it easy, was trying to avoid putting one in.
Old 04-03-2020, 06:45 PM   #4
PGSigns
PGSigns's Avatar
Re: 82 rear lower
It would be your best way of getting what you want.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 04-04-2020, 01:11 AM   #5
Ziegelsteinfaust
Re: 82 rear lower
I think he is beyond doing a flip kit.
A flip kit usually nets about 6" of drop.
His bracket lowering is usually good for 4 inches depending on manufacturers. So combine the 2, and he is on the ground.
I see only 2 options here.
1. De-arching your springs for the drop you want, and using your adjustable shackle to dial it in. First I would run the bolts down a couple of notches. That way you build in some adjustments.
2. Put the factory hangers back on, and the so a flip kit.
Ziegelsteinfaust is offline   Reply With Quote
