04-27-2020, 12:51 PM | #1 |
1974 Suburban Tailgate Question
Hi - Has anyone removed this fiberglass(?) part that goes between the tailgate window and the body on a 1974 Suburban? I would appreciate any advice on how to safely remove and re-install this piece. Thanks!
04-30-2020, 06:57 PM | #2 |
Re: 1974 Suburban Tailgate Question
I'm gonna stick my neck out that if you pull the window seal there are bolts or screws in there. Look at a barn door truck and you can see what it can possibly bolt to.
I had them, but never pulled that off.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
04-30-2020, 07:34 PM | #3 | |
I think you remove the LH and RH side pieces first and then the center. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
06-07-2020, 12:31 PM | #4 |
and you will likely destroy the seal when you remove.
LMC has them though. |
08-02-2020, 12:33 PM | #5 |
Here is what I found: Remove the upper glass run felt, remove the screws for the tailgate seal, then you can remove the sheet metal screws holding the three pieces in place. Keith was correct - remove the side pieces first then the top. There is a rubber seal between the fiberglass parts and the body.
Note: The 1973-74 Suburbans use a separate upper glass felt run and a separate lower tailgate rubber seal. The 1975+ Suburbans use a one-piece felt run/tailgate seal. Last edited by Bryan_C; 08-02-2020 at 12:41 PM. |
