Old 05-08-2020, 03:00 PM   #1
hatzie
Moderator
hatzie's Avatar
Thread suggestions for the 99-07 GMT800 FAQ
Just like the label says. Thread suggestions for the GMT800 FAQ.
Post good threads.
I'd like to break it up into at least six broad topics;
  • Electrical
  • Interior
  • Exterior body
  • Brakes-steering-suspension
  • Driveline
  • Wheels & Tires
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 05-11-2020, 11:07 PM   #2
OldCreek
OldCreek's Avatar
Re: Thread suggestions for the 99-07 GMT800 FAQ
driveline: Transfer Case rub through, Transfer Case slip joint clunking.
interior: A/C selector motor replacement, A/C drain plug removal/opening, dash and a/c light bulb replacement/solder, instrument panel motor replacement, tow select replacement, Automatic column shift handle spring replacement.
Exterior: Hood/Grill exchange for other years.
Engine: oil cooler line leak/replacement
to start with...
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 05-16-2020, 04:37 PM   #3
hatzie
Moderator
hatzie's Avatar
This is a rough outline not a refined finished product.
I'm looking for threads from this forum to fill this. I've started looking through the posts in this forum starting with the oldest.
If you have additional topics that's great but we need threads to go with them.
GMT800 1999-2007 GM Fullsize light Trucks and SUVs FAQ
VIN number info
http://67-72chevytrucks.com/vboard/s...d.php?t=483883
Interior
-Front Door panel removal:
-EXT cab Rear Door panel removal:
-Crew Cab Rear Door panel removal:
-Floor courtesy light installation using factory junction panel connection:
-Glovebox light install:
-GMT900 AZ3 three cup jump seat retrofit:
-Jump seat to Console:
-Console to Jump seat:
-Ext cab rear under seat storage:
-Crew Cab rear under seat storage:
-Tow select switch replacement:
-Loose auto column shifter fix:
http://67-72chevytrucks.com/vboard/s...d.php?t=341677
HVAC
-Blend and mode door actuator replacment:
-A/C Evaporator drain service:
-HVAC panel lamp replacment:
-Cabin air filter pair OEM 1999-2002:
http://67-72chevytrucks.com/vboard/s...d.php?t=274151
-Cabin Air Filter retrofit 2003-2007 (Some GMT900 2007-2014):
http://67-72chevytrucks.com/vboard/s...03&postcount=9
Electrical and electronics
-Oil Life warning reset without UK3 steering wheel DIC control buttons option:
http://67-72chevytrucks.com/vboard/s...d.php?t=238195
-Remote Keyless Entry Fob Programming:
http://67-72chevytrucks.com/vboard/s...d.php?t=180448
-GM Theft-Loc radio unlock using Autel or Snap On Verus Bi-Directional Diag tool:
https://www.youtube.com/watch?v=QzZMyUzeeEc
-Gentex compass/temp mirror upgrade:
http://67-72chevytrucks.com/vboard/s...d.php?t=214894
-Instrument Cluster Stepper motor replacement:
http://67-72chevytrucks.com/vboard/s...d.php?t=511327
-GM Trailer light wiring:
-GM Camper light wiring:
Body
-Forward body and lighting style swaps (99-02 03-07 Silverado or Silverado to Sierra front ends or the other direction):
-Ignition, door, and spare tire lock cylinder re-keying:
http://67-72chevytrucks.com/vboard/s...8&postcount=22
-Cab roof clearance lights retrofit using factory junction panel wiring connection:
-Tail lamp swaps Red Late Silverado to Amber/Red GMC & Early-Silverado:
-Forward lamp replacement:
-Side Mirrors:
-Folding Mirrors:
-Towing Mirrors:
-Rustproofing:
--WoolWax http://67-72chevytrucks.com/vboard/s...d.php?t=806378
Suspension-Steering-Brakes
-Shock absorber R&R:
-Torsion spring crossmember bushing replacement:
-Parking brake reline:
-ABS Bleed:
-Brake system flush:
-Front control arms:
-Control arm bushings:
-Ball joints:
-Tie rods:
-Pitman arm:
-Idler arm:
-Steering gearbox:
-Steering rack:
-Wheel hub replacement:
http://67-72chevytrucks.com/vboard/s...d.php?t=513501
Fuel system
-Fuel Pressure regulator replacement:
http://67-72chevytrucks.com/vboard/s...d.php?t=430723
-Fuel-pump/sender module R & R:
Emissions engine control system
-EVAP diagnosis:
-Misfire diagnosis:
-Detonation/Knock sensor diagnosis:
Driveline
-New Venture transfer case oil pump rub through prevention/fix:
Cooling system
-Oil cooler line repair:
-Oil cooler line replacment:
-Transmission cooler line repair:
-Transmission cooler line replacement:
-Hayden Tru-Cool LPD AUX transmission cooler retrofit in factory cooler location:
Wheels and Tires
GM Factory wheel options:
Old 05-16-2020, 09:51 PM   #4
70cst
70cst's Avatar
Signed on ...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 05-17-2020, 08:03 AM   #5
Good thought process into the overview/outline. Looks great.
Old 05-17-2020, 09:05 AM   #6
70cst
70cst's Avatar
One area that I am working on is Rustproofing ... many of these old trucks would benefit from such a treatment. .
The truck I just purchased came form SC so it hasn't encountered no salt and snow thus ... it doesn't have the typical GM Rust.
I looked at Zierbart, Fluid Fill, and WoolWax.
I am going with WoolWax - will get my truck treated in a couple weeks.
Old 05-30-2020, 04:30 PM   #7
hatzie
Moderator
hatzie's Avatar
Adding more links to the FAQ Sticky.
GM owner manuals straight from GM.
