Old 05-09-2020, 10:30 PM   #1
tbrown5079
Opinion on brake boosters
I built a sweet 56 cameo with a 4.8 LS engine and a GM A body front clip. Lots of other upgrades. Happy with everything but the brakes. I used a firewall mounted kit with a 7" power booster and swing pedal bracket for under the dash from a popular Chevy truck supplier. I had the booster replaced once (lifetime warranty). The engine is stock with low miles and has 20" of vacuum at idle. The brakes work OK, but I just can't really set it down like I may have to sometime. They have 8 and 9 inch boosters with single and dual diaphragm that would fit my kit. I have room for a larger booster. The mounting is 4 bolt 3 3/8". Is bigger better and why do they use dual diaphragm now instead of single like they did before? Your thoughts? Suggestions? Tbrown
tbrown's 56 Cameo Build
tbrown5079 is offline   Reply With Quote
Old 05-10-2020, 10:34 PM   #2
mick53
Re: Opinion on brake boosters
Wilwood recommended 8" duel diaphragm for my 6 piston front and 4 piston rear, I have no manifold vacuum so I'm running an electric vacuum pump. I took the engine out of the loop.
mick53 is offline   Reply With Quote
Old 05-10-2020, 10:43 PM   #3
whitedog76
Ever thought about hydroboost? Having an LS drivetrain, and I'm assuming power steering, shouldn't be too hard of a retrofit.
whitedog76 is offline   Reply With Quote
