Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Forums > Past Contest Winners > 2020 ToTM Archive
Closed Thread
Old 05-15-2020, 10:12 AM   #1
June 2020 ToTM
For our June 2020 Truck of the Month (ToTM) contest the theme is
Old Mule
As you will see, I limited the years of trucks to cover as many as I can, but not get the new stuff that many are using for work. The idea is for those older trucks that we got and tweaked (either by the current owner or someone prior to their ownership) to fit a specific job or series of work tasks.
Here are the criteria for this month’s contest.
  • Open to all 1998 and older models of trucks.
  • The nominee must be a board member and the current owner of the truck.
  • The must be together and able to move on its own power.
  • If a truck was selected as a 2020 ToTM winner then you are ineligible. If the truck was nominated but not selected as a ToTM winner then it may be nominated and compete in this month's category.
To Nominate:
You or someone else may nominate the vehicle. The nominee must be a board member and the current owner of the truck. Once you decide on who you wish to nominate, just add your nomination to this thread. One key aspect is we need 1 full picture of the truck and 1 showing it doing its work or tasks. This could be hauling loads or towing. In addition, we will need the owner’s board name and the Make/Model/Year of vehicle.
Nominations will run through May 24. The first 15 nominees that meet the criteria will participate in the contest We will need two pictures minimum (at least one full view of the vehicle) with/for the nomination as well as the owner’s board name, the Make/Model/Year of vehicle. I will PM the nominees to get any additional data or pictures if they have not already been provided. If the owner has a preferred picture they want used in the contest, please let me know in a PM. You can PM me for an e-mail address in case anyone has problems resizing the pictures for the board. A Poll Thread will be set up May 25 in this board area and an announcement will be posted on the Discussion Boards to notify all that voting has begun. The Poll will run thru the morning of June 1 and the official announcement of the winner will be on the evening of June 1. The announcement of the ToTM winner will be posted through the General Discussion Board area.
Palf70Step is offline
Old 05-15-2020, 02:01 PM   #2
oem4me
Re: June 2020 ToTM
Here's one real deal 1962 C20. Not heavily modified, but a bone-stock legit original survivor. Properly set up for work with period correct toolbox and lumber rack.
235 six, 3 speed on the column (with overdrive), 410 rear, and crazy tall 19.5's. This is the "old man" of my small collection. I've had it the longest, worked it the hardest, and probably enjoyed it the most!
oem4me is offline
Old 05-15-2020, 03:20 PM   #3
jbgroby
jbgroby's Avatar
Re: June 2020 ToTM
Day 1
jbgroby is offline
Old 05-15-2020, 09:08 PM   #4
weim55
Re: June 2020 ToTM
I nominate JDLs Iowa based ‘71 Longhorn. A wonderful old survivor with a number of well done modifications to be the ultimate fifth wheel hauler back in the day.........
Steve weim55 Colorado
weim55 is offline
Old 05-15-2020, 10:37 PM   #5
weim55
Re: June 2020 ToTM
Some features JDL shared about this GMC:
Tag axle Fully retractable and controlled hydraulically with valving split through the power steering pump, tag axle has functioning brakes as well!
Doug Nash Overdrive behind the turbo 400.
Second alternator for additional charging.
Modified big block for additional towing power.
Stock AM radio plus FM cassette deck PLUS 8track player.
I’m sure there’s more I don’t know about......
Check out this fabricated bumper, Stout!
weim55 is offline
Old 05-15-2020, 11:23 PM   #6
JDL
JDL's Avatar
Re: June 2020 ToTM
I just got this truck still finding new things about it. This truck has been acros the country and back stickers from most western and the south even Alaska. The camper in the pick was originally a slide in bot new in Idaho and they drove out to get it in 84 and it is in the order that he had the tag axle on it thin. I have drove it local and on a couple trips over 200 mile it did well and got some attention.
72 Chevy short step side with 454 air and tilt.
72 nova project car
63 chevy II drag car
Agency Iowa
JDL is offline
Old 05-21-2020, 07:25 PM   #7
3757chevy
3757chevy's Avatar
Re: June 2020 ToTM
I nominate special-K.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline
Closed Thread
