Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 06-07-2020, 02:01 PM   #1
creep
Registered Loser
creep's Avatar
2014 Silverado A\C Blowing Hot.
The A\C in my 2014 Silverado just quit working and after doing some searches I've found that its a pretty common problem. Has anyone on here experienced this and were you able to get GM to do anything about it (out of warranty)? sounds like they are denying its a problem even though there are a few TSB about it.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 06-08-2020, 02:57 PM   #2
Re: 2014 Silverado A\C Blowing Hot.
It could be a blend door, could be your compressor or the switch that activates it, or could be just low on Freon. I would check freon level first as if it hits a certain level, it just quits.
Old 06-08-2020, 09:12 PM   #3
LEEVON
LEEVON's Avatar
TSB's are just service information. You're waaay out of warranty on that...GM is not involved anymore. Yes its a problem on those trucks and they fixed many under warranty. Condenser failure is common, there is an updated part. I think there is a hose or line rub issue too. We do quite a few in my shop. If the compressor, condenser, line etc get replaced its expensive, sorry : (
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 08-10-2020, 03:38 PM   #4
jjzepplin
jjzepplin's Avatar
Did you ever figure this out?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
