Old 06-13-2020, 09:28 PM   #1
clay68c10
clay68c10's Avatar
Motorhome Tilt Column, bolt in ready
$250 local, $300 shipped
Please respond in thread only per board rules, first "I'll take it" gets it.
Selling a motorhome tilt column. From a mid 80s GM chassis
I moved the NSS down so it's a bolt-in for your 67-72;
I used my multi-meter to adjust it, you may need to fine tune it after install.
Turn signal has no lever
Turn signal switch is tight and cancels as it should
Includes the cancel cam
The gray illumination wire is fairly long
Includes a long pigtail for the Neutral Safety/Reverse switch
Tilt mechanism is tight and smooth.
The 4 bolts in the tilt mechanism that typically loosen over time have been removed and reinstalled with lock-tight.
Tilt pivots were cleaned and lubed when removed to tighten the bolts.
The bottom bearing was cleaned and greased
The upper bearings were cleaned and greased
The shift indicator bulb was replaced and tested OK, it has the green shade on it.
Shifter lever end (inside column) is good, pivot is average
Shift arm and adjuster lever have nice chrome, they shine up well.
The finish on it is OK, great for a driver. Some scratches as pictured. It would probably buff out nicely.
I will include a new GMC Paul's gear indicator, pics are with the old original
You will need to add your dash and firewall gaskets, as well as the firewall plate.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 06-13-2020, 09:36 PM   #2
clay68c10
clay68c10's Avatar
Re: Motorhome Tilt Column, bolt in ready
More pics
13 Tahoe LTZ
Old 06-14-2020, 05:39 PM   #3
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
I'll give you 250.00 shipped. Please let me know. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 06-15-2020, 08:32 AM   #4
clay68c10
clay68c10's Avatar
Can we meet in the middle at $275?
13 Tahoe LTZ
Old 06-15-2020, 12:23 PM   #5
Classic Heartbeat
PM returned. Yes we can meet in the middle. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 06-15-2020, 12:58 PM   #6
clay68c10
clay68c10's Avatar
Sounds great
Sold to Wes
13 Tahoe LTZ
Old 06-15-2020, 08:22 PM   #7
clay68c10
clay68c10's Avatar
PM sent. Shipping out tomorrow.
13 Tahoe LTZ
column, steering, tilt
