06-16-2020, 12:52 AM | #1 |
1960 Apache C10 Transmission Mount
Does anybody know off the top of their head what size the bolts are that hold the transmission mounts to the crossmembers, or know if anybody sells these bellhousing mounts?
I am apparently missing the bolt and nut / washer on the passenger side - and the mount looks pretty beat too... THnaks! |
06-16-2020, 09:32 AM | #2 |
Re: 1960 Apache C10 Transmission Mount
Does your mount look kinda like mine? I'm not sure exactly what the 60 mount looks like. If it looks the same, I can go put a socket on my bolt to check the size
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
06-16-2020, 09:42 AM | #3 |
That mount is an "Anchor 2107"
06-16-2020, 12:19 PM | #5 |
Those are the same mounts as on my 63. I can roll underneath and check the bolt size for you later today. You might also be missing the rubber piece that goes on the bottom side of the crossmember
06-16-2020, 10:35 PM | #6 |
The one underneath is "Anchor 2108"
06-16-2020, 11:02 PM | #7 | ||
It sounds like Dave has this one nailed ... I just need to get a grade 8 bolt thats will fit through there, and use both mounts? you two guys are the best! |
06-17-2020, 07:31 PM | #8 |
Sorry, I forgot to check the size yesterday.
The bolt goes through both mounts from the bottom up to the bell housing. The bolt is a 3/4". I know it is coarse thread, but I didn't pull the bolt out to check the length. With the rubber part inside the crossmember, the bolt head is close to being flush with the bottom of the crossmember
06-17-2020, 09:58 PM | #9 |
60-66 Nut
The bolts are 1/2"-13 X 3-1/2". Bolts are not designated by the size of the hex.
06-17-2020, 11:32 PM | #10 | ||
Thanks guys! I will try and get one rounded up tomorrow, for the weekend. You are both greatly appreciated |
