Old 06-22-2020, 10:17 AM   #1
apound
Factory cab assembly sequence
Does anyone have any info, pictures, etc about the sequence that the factory assembled the 67-72 cabs? Just the Sheetmetal is all I'm concerned with not the trim. Or any photos of the jigs they used?
apound is offline   Reply With Quote
Old 06-22-2020, 04:02 PM   #2
toolboxchev
Re: Factory cab assembly sequence
This is going to be a good one.......
Back TTT
toolboxchev is offline   Reply With Quote
Old 06-23-2020, 01:25 PM   #3
May70
May70's Avatar
Very interested to see what comes from this one as well.
70 C20 Build link : Project Montezuma
http://67-72chevytrucks.com/vboard/s...d.php?t=794479
How to repair that rusted out 67-72 c10-c30! Please subscribe!
https://www.youtube.com/c/MaycoCustomRestorations
May70 is offline   Reply With Quote
Old 06-23-2020, 02:36 PM   #4
Davidf
I suspect not much will come of this thread.
Davidf is offline   Reply With Quote
Old 06-23-2020, 06:50 PM   #5
AussieinNC
Moderator
AussieinNC's Avatar
I think image storage sites like pinterest etc would be a good resource....it will take some time but if anyone has posted them up, you should be able to find them....
There is also the Factory Assembly Manual would be a good resource if you are looking for detailed specs..
https://www.performanceonline.com/19...SEMBLY-MANUAL/
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 06-24-2020, 02:29 PM   #6
Keith Seymore
Keith Seymore's Avatar
I don't believe there is a central repository of '67-72 photos, so this is as good a place as any to make one.
The assembly manual is a good thought, as it will show the specific components and the order they went together.
Basically the floor pan goes down first. Front of dash and cowl pieces are next. Then door rings, then rear panel and front windshield panel. Roof outer goes on last.
Those are the major components; naturally there are a bunch of smaller fillers and brackets.
Squarebody pictures will be easier to find. The pickup cab shop was highly automated by that time but the Flint Line 2 cab shop (Blazer and Suburban) was still very much a manual process and would be more similar to '67-72.
Some Flint photos here: http://www.73-87.com/7387info/Assembly%20Line.htm (pictures 5, 6, 7).
There are older truck photos and passenger car photos on the web that would give you the basic idea. I'll post those up as I come across them.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 06-24-2020, 02:32 PM   #7
Keith Seymore
Google "Pontiac Passenger car assembly" and you will find a ton of passenger car stuff that would be similar.
Let me know if you have any specific questions after viewing all those.
K
https://www.youtube.com/results?sear...c+car+assembly
1979-1986
1986 - 2019
Old 06-24-2020, 05:14 PM   #8
Davidf
K
Reference photo #10, is that what the large plugged hole in our doors was for...rust proofing the bottom seam?
I just completed rust repair on both of my doors and they are freshly painted and re-hung. I had planned on mixing a transmission/oil/grease mix, temporarily plugging the drain holes and pouring in the mix so it seeps into the seem. Let sit, drain, protected somewhat.
Old 06-24-2020, 06:33 PM   #9
Keith Seymore
Yep. The inside of the door (not just the seam).
K
1979-1986
1986 - 2019
Old 06-24-2020, 08:37 PM   #10
Davidf
K
So, are they spraying in the sound deadening through that hole?
Old 06-25-2020, 02:11 PM   #11
Keith Seymore
No, not sound deadening. Wax type corrosion protection.
K
1979-1986
1986 - 2019
Old 06-25-2020, 03:51 PM   #12
GMC 72 4X4
Reprinted copy's of the factory assembly manual are available, if you don't want to buy one see if someone will loan you their copy. It's about 600 pages of drawings and will tell you all the necessary dimensions right down to the factory spot weld locations.
72 GMC 4x4
GMC 72 4X4 is offline   Reply With Quote
assembly line, cab, factory
