Old 06-22-2020, 01:20 PM   #1
tdangle
tdangle's Avatar
Vacuum boost to hydro boost conversion
For those of you that have done this on a 67-72
The stock vacuum booster setup has a pivoting linkage setup on the engine side of the firewall. Did you eliminate this and now the brake rod goes straight from the brake pedal to the booster unit?
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 06-23-2020, 12:05 PM   #2
Bigdav160
Bigdav160's Avatar
Re: Vacuum boost to hydro boost conversion
Mine's hanging from the linkage/bracket
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 07-05-2020, 07:18 AM   #3
dennislbrooks
dennislbrooks's Avatar
I did mine as you described.
I had make a new mount for the firewall. It has been a while and this is before the vendors started making custom kits. Mine is still this way below and works great.
http://67-72chevytrucks.com/vboard/s...d.php?t=175714[
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
