Old 07-01-2020, 11:53 AM   #1
sdkid
04 Chevy 1500 A/C issue
Has the electronic panel with dual zone control. Driver side goes full heat sometimes. Can someone tell me the location of the actuator for the driver side?
I think the world needs a drink...
Help somebody...If you can....VanZant
We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
'68 c10 no eng/trans fac ps/pb/ac/at
(future father/sons project)
'48 Chevy Loadmaster
sdkid is offline   Reply With Quote
Old 07-02-2020, 02:55 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: 04 Chevy 1500 A/C issue
Driver side is on top of the heater box.
You have to pull the dash cover and the duct that passes over the top of the heater box.
The passenger side is a lot easier. Just pull the beauty cover and the actuator motor is right on the bottom of the heater box.
Have you tried resetting the HVAC controller?
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 07-02-2020, 03:48 PM   #3
Bob B.
Hold it, I think the left (driver's side) temp actuator is the one on the bottom of the HVAC case. BTW, sometimes you can get the top temp. actuator off by removing the radio and reaching in. By all means try the reset first, that often fixes the problem.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 07-06-2020, 04:32 PM   #4
sdkid
How do I do the reset?
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
Old 07-06-2020, 06:59 PM   #5
hatzie
Moderator
hatzie's Avatar
03-07 AUTOMATIC HVAC with the digital display.
  1. Start the truck and set the HVAC controls to AUTO.
  2. Shut off the truck
  3. Pull the HVAC/ECAS fuse in the underhood fuse relay block.
  4. Leave the fuse out for 2 full minutes.
  5. Re-install the fuse.
  6. Start the truck and wait til the HVAC finishes calibrating all the motors. It'll take a couple minutes.
  7. Switch the truck off for full 15-20 seconds.
  8. Restart the truck and check that it works now.
Old 07-08-2020, 10:59 PM   #6
sdkid
Thank you Hatzie!!!
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
Old 07-09-2020, 04:34 PM   #7
hatzie
Moderator
hatzie's Avatar
Did it work for you?
Old 07-11-2020, 11:08 AM   #8
sdkid
Seemed ok until this morning. I've had it full cold. This morning I turned it to 70ish, then it went full hot on the driver side.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
Old 07-11-2020, 03:22 PM   #9
hatzie
Moderator
hatzie's Avatar
Just looked at the service books. I was incorrect. The RH blend motor is on top of the airbox.
The LH motor is on the bottom of the HVAC box under the beauty cover and it's darn easy to R&R.
I've read conflicting information. I trust GM.
Pull the heater fuse referenced above before you remove the motor and don't plug it back in til the new one is installed and you're ready to calibrate it.
Re-cal the system after you finish installing the motor.
Old 07-15-2020, 06:32 PM   #10
sdkid
Thank you sir. I will update you.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
