Old 07-12-2020, 12:44 PM   #1
dennislbrooks
dennislbrooks's Avatar
differences in calipers
Does anyone know if there are any differences in a 72 c10 front caliper and a 84 K10 front caliper other than maybe the brake fitting?
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 07-12-2020, 01:10 PM   #2
sweetk30
sweetk30's Avatar
Re: differences in calipers
1972 c-10 front https://www.rockauto.com/en/moreinfo...410073&jsn=470
1984 k10 https://www.rockauto.com/en/moreinfo...299708&jsn=609
the banjo bolt hole will be american / 72 and then metric for 84
the body is the same basic shape but you might need to grind a bit for a casting nub to clear hear and there . been to long since i played with that stuff to recall .
2 links tho have a few pics to show you .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 07-12-2020, 05:40 PM   #3
dennislbrooks
sweetk30, thanks, I will try my 72 c10 calipers which because of the 59 straight axle have extra long rubber lines now. Just was hoping not to have to buy the 84 since the 72's are new rebuilt stuff. I have completed the gear change in the 84 GM 10 bolt to match the rear on my 59 GMC 3.07 to 3.73.
Yea, I looked at rockauto to see if they had different part numbers.
Old 07-17-2020, 09:32 AM   #4
dennislbrooks
To my question about 1972 c10 calipers working on a 1984 K10 front axle.
Answer is NO.
