Old 07-20-2020, 01:39 PM   #1
mick53
bore spacing
Hi folks, first I have to give a retraction. I had stated that I was getting a 24 port 24 valve cross flow head for my 292. I was looking at an airplane head or something else. The head I'm actually getting is a 12 port 12 valve aluminum cross flow. On one of the "I'm smarter than anybody and your an idiot" forums it was stated that the bore spacing on the head would never work on an I6. Freaked out a little I called Ryan Falconer today and ask him. It's the same. In the process it accrued to me that the I6 and the SBC have the same bore spacing. Was this a product of the manufacturing and/or the casting process when they started producing the SBC?
mick53 is offline   Reply With Quote
Old 07-20-2020, 04:20 PM   #2
mr48chev
mr48chev's Avatar
Re: bore spacing
Small blocks came years before the late six but evidently the engineers kept the bore spacing.
I'm thinking that someone cut the ends off small block heads To bolt them to a late six back in the 70's. This is one that Rotten Leonard on the Hamb was building
My ongoing truck projects:
Old 07-20-2020, 08:00 PM   #3
joedoh
joedoh's Avatar
Re: bore spacing
i have worked in engineering/manufacturing most of my career and I can tell you that derivative designs are really common, I have seen aircraft design engineers take lofts from older aircraft designs and I have personally seen the production line pin locations on trucks 35 years apart line up exactly. it wouldnt surprise me at all if the spacing was the same on purpose, because if it works dont fix it!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 07-20-2020, 09:29 PM   #4
mick53
Re: bore spacing
I also just noticed that after over 40 years of owning my truck that the 235 is 2" off center to the right?
Old 07-20-2020, 10:05 PM   #5
1project2many
Re: bore spacing
GM always seemed to be good at determining where not to spend money reinventing the wheel. They seemed to like the 4.4" cylinder centerline.
Here's a partial list of engine families using 4.4" bore spacing:
Smalblock Chevrolet, 262 through 400 ci
Chevrolet I6 including 235, 250, and 292 ci
GM 60 degree V6 including 2.8l through 3.9l engines
For years it seemed like Ford reinvented the wheel every time they built a new vehicle. Of course it wasn't true, but it just seemed like soo many parts were unlikely to fit without extra work if brought from one carline to another or from one engine to another.
1project2many is offline   Reply With Quote
Old 07-21-2020, 01:19 AM   #6
mr48chev
mr48chev's Avatar
Re: bore spacing
You can never assume that anything on a Ford made after 1960 is going to be The same as as it is on another Ford of the same model. On late 60's early 70's Mustangs we used to joke that we had to know the factory color to get the right parts. If it had this engine it had these brakes, if it had that engine it had those brakes. You had to write down the vin when you went for parts.
Chevy = All of a certain year and model had the same stuff or the HD package had bigger stuff.
Old 07-23-2020, 12:19 PM   #7
_Ogre
_Ogre's Avatar
Re: bore spacing
i always said if you needed a junk yard motor for your red 64 ford car, make sure you find a red 64 ford to pull the motor out of.
i won a 64 for wagon in a poker game, i had no use for it and sold it to a friend that needed a motor for his ford van. he pulled both motors before figuring out the motor wouldn't fit. luckily he was able to sell everything to recoup his money
shop air compressor timer
Old 07-23-2020, 12:23 PM   #8
_Ogre
_Ogre's Avatar
Re: bore spacing
interesting, gm also liked to keep bellhousing patterns the same
i believe the new sbc will bolt up to the old belhousings with the exception of the top bolt
not gm but the aftermarket also makes the sbc 454
Old 07-23-2020, 12:32 PM   #9
mr48chev
mr48chev's Avatar
Re: bore spacing
I'm just thinking that I might have to make a road trip to hear Mick's engine run some day. I've wanted to do a road trip to Indiana anyhow.
Old 07-23-2020, 02:53 PM   #10
mick53
Re: bore spacing
My new head shipped. Should have it Monday.
Old 07-23-2020, 10:13 PM   #11
1project2many
Re: bore spacing
I am enjoying your truck build. Can't wait to hear it running.
