07-23-2020, 08:55 PM | #1 |
Junior Member
Grill support pannel
Hi guys i had to replace my grill support panel po ran truck into a pole, bought a new one from LMC matches up perfect with fenders but 4 head light assembly will not fit nothing lines up its way wrong what have i done wrong. 61 chevy apache.
07-23-2020, 09:06 PM | #2 |
Re: Grill support pannel
Sounds like either a really bad repop or possibly you received the wrong year, which happens more often than you would think (in general, I'm not singling out LMC).
My truck ain't dead, it just smells funny. |
07-23-2020, 09:13 PM | #3 |
Do you still have the original one? Compare the two extensively and see if you find any differences, especially related to different bolt holes
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
07-23-2020, 09:26 PM | #4 |
Junior Member
Thanks guys don,t have original done a dump run with damaged front end parts i take it there has to be different pannels , Lmc says lt flts 60-63 which it does not.would appreciate any suggestion on where to buy correct one, can,t afford to loose money on wrong parts.
07-23-2020, 10:31 PM | #5 |
60-66 Nut
Here is the correct one. the '60-'63 are not all the same.
https://www.classicparts.com/1960-62...nfo/61%2D716A/
07-23-2020, 10:44 PM | #6 |
Junior Member
Thanks captainfab will get one ordered.
07-28-2020, 03:58 PM | #7 |
I'm just glad to be here!
I had picked one up years ago in a yard before they even started reproducing them. I ended up just centering the grill and redrilled the holes as needed.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
08-01-2020, 12:54 PM | #8 |
i put a 61 grill on my 65 i agree with aggie91 jst center and drill jst make sure U got a good ground for the lights ...
Thread Tools | |
Display Modes | |
