07-27-2020, 01:30 PM | #1 |
Shifter collar
Where can I get a new shifter collar for 69 Chev Pickup tilt column?
The hole at the bottom is worn and the shifter is sloppy |
07-27-2020, 01:42 PM | #2 | |
Re: Shifter collar
There is plenty of pre- made bushings around, OR you can just make your own . |
07-27-2020, 01:58 PM | #3 |
Re: Shifter collar
What kind of bushing?
How do I hold it in as the worn side is on the bottom. |
07-27-2020, 02:39 PM | #4 |
Re: Shifter collar
Some good hardware stores have small metal bushings in the little pull out bins. I'm not sure if you have Ace up there but they usually have them in the little pull out drawers above the bolt bins if you hunt. You need to know the ID and probably take the pin as your sample.
07-27-2020, 02:45 PM | #5 |
Re: Shifter collar
Thanks - I'll see if I can find something but our hardware stores aren't as good as yours. Should I locktite it in?
07-27-2020, 06:50 PM | #6 |
Re: Shifter collar
