Old 07-27-2020, 04:05 PM   #1
siggyfreud
siggyfreud's Avatar
Relocate Sway bar mount on Ridetech lower control arms to resolve wheel clearance?
Looking for opinions on a problem. I'm running 20x10" wheels in the front of my 72 C10, and after swapping over to ridetech suspension I'm finding that my wheels are running into the swaybar mounts on the LCAs. At first, I was going to build some steering stops, but unfortunately, the interference gets worse when weighted up, and it really is going to limit my turn radius more than I'd like.
Now I'm thinking about relocating the sway bar mounting pad to the inside of the lower control arm, which would completely resolve the interference issue.
Curios what you suspension gurus think. Will it mess with the geometry too much, or has anyone done this before?
Conversely, I could mount it on the same side of the control arm, but on top instead of bottom, if I could find or fab new end links.
siggyfreud is offline   Reply With Quote
Old 07-28-2020, 12:15 PM   #2
SCOTI
SCOTI's Avatar
Re: Relocate Sway bar mount on Ridetech lower control arms to resolve wheel clearance
I don't see how shifting it from where it is to the inner portion of the arm would make any significant impact since it's just 1.5" tube. To me top or bottom would work & I would choose whichever location best suits the clearance for everything.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
