07-29-2020, 02:02 AM | #1 |
Tailgate link/arm bumpers
Could someone measure the location of these for me? Need to re-drill the location. With all the screw holes in the rear stake pillars guess I ended up welding up the holes.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
07-30-2020, 09:16 PM | #2 |
Re: Tailgate link/arm bumpers
No one?
07-30-2020, 10:40 PM | #3 |
The thick one by my eye measures 7 3/8" up from the lower end the stake pillar and 1/2" in from the outer brake radius. The small button one on top should be drilled in the middle of the depression.
Smitty '71 Short Fleetside Spring Valley, Ca. |
07-31-2020, 02:35 AM | #4 |
Thank you for taking the time. I am good with the button bumper. Is the measurement to the edge of the rectangular bumper or to center where screw attachment is?
07-31-2020, 07:35 AM | #5 |
Should be to center. As close as I could see to a hole in a rubber block. Let me go out and double check this morning when there is better light. Last night was with a flashlight. I’ll post measurements again. Was using a machinist square and the increments are so close. With poorer light they may be off a bit. I measured from where the stake fitting meets the rear sill plate.
07-31-2020, 08:09 AM | #6 |
8 1/2 inches down from the buttonhole. 1 inch in from the inner face of the stake pocket to the hole (hole-center) for the square bumper.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 Last edited by sick472; 07-31-2020 at 12:02 PM. Reason: Added the word "hole-center" to be clear |
07-31-2020, 11:34 AM | #7 |
Richard
Remeasured a little while ago. The 7 3/8 dimension is good. As is 472's, just taken from a different dimension. As for the other mine measures 1/2 in to center. Not sure if 472 was measuring to center of hole or outside of the bumper. But if he measured to the outside of the bumper both dimensions would be the same.
08-01-2020, 12:44 AM | #8 |
Thank you both for this.
08-01-2020, 08:47 AM | #9 |
Sorry I was slow, but glad I could help.
08-02-2020, 04:15 AM | #10 |
NP, will not fit tailgate until next week. Thanks again to you and sick472 who took the time to do this for me.
