cat converters
anyone added Catalytic Converters to a dual exhaust system? my wife complains about exhaust smell from my 327 and a friend recomended adding cats to clean up the smell. any thoughts or ideas would be appreciated. Thanks
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's Bought in 1973 for $235.00. Had it longer than my wife & Kids!! |
Re: cat converters
Cats to clean up the smell? Sorry, but they do just the opposite. When I drive over my local mountain passes the rotten egg stink from all the hot catalytic converters is nauseating.
Maybe your truck is running too rich?
1951 Chevy Panel Truck |
Re: cat converters
If there is a smell it isn't because of a missing cat. It is because the fuel system isn't adjusted correctly or your exhaust exits out from under the truck in the wrong place. It does exit from out under the truck and not under the truck?
Re: cat converters
ok, you got me. the exhaust does dump straight out in front of the axle. and maybe the carb is running rich. maybe i should leave it that way & my wife will want to stay home. JUST JOKING !!!!
Re: cat converters
Haha, try some fuel fragrance. My favorite is Groovy Grape:
https://www.powerpluslubricants.com/...ragrances.html
Re: cat converters
When I lived in Texas I had a buddy who had a 60's Mopar with a big block who ran turbos with the exhaust dumping down in front of the rear axle under the car. Serious fumes while cruising around town and a headache making drone going down the road. I rode with him to the drags at Little River once and about hooked a ride back with someone else.
No excuse for a carb that isn't tuned right so it doesn't run rich though.
Re: cat converters
mpc - what kind of a scam is this fuel fragrance ???
Re: cat converters
There are dozens of scents, including one called Reefer Madness that makes your exhaust smell like burning marijuana:
Re: cat converters
That is too funny, scented exhaust.
#10 | ||
Re: cat converters
Not a scam. It works. Covers the smell of illegal... err... "reformulated" race fuel. Also helps make nitro smell better.
Some cam designs are more likely to cause rich exhaust at idle. Too much overlap at low engine speed can allow exhaust gas into the intake and can cause partial combustion. It actually acts like EGR by cooling and slowing the reaction. Are you running a stock cam? Quote:
Re: cat converters
ok, no its not a stock cam/ engine etc. its a 327 block, bored 30 over, 4 bolt mains, 194 heads high lift cam & a whole lot of stuff i cant remember. it was originally built for a sprint car & wound up in my truck in 1973. so i will start by tuning the carb & timing & see if that helps.
![]() Join Date: Feb 2004
Re: cat converters
Ok, I'll bite. I did run cats on my 67 swb with a crate 350 with an edelbrock 600. They need to be up near the engine to work correctly as they do need to be hot. And yes I think the exhaust smell was better with them. I agree running too rich is a noxious smell. Tune and if that does not do it run an oxygen sensor and gauge and run cats. Run unleaded.
I do not run cats now with a bbc and a qjet but I would not be afraid to run them again if sized correctly.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 08-15-2020 at 03:46 PM. Reason: words |
#13 |
Re: cat converters
The only viable reason to run cats on a pre 75 rig is that your state requires them because of the year model of the engine you installed. In the "must meet emission requirements for the year model of the engine installed."
It works the other way around too. I know of one guy in this state that stuck a mid 60's 327 in an 81 Camaro during a rebuild (car was bought from the same outfit I bought one from with a bad engine and salvage papers) and flunked the state inspection. The guy pulled the 305 out, stuck a 327 he had in and took it to inspection and the inspector failed it. That from the same inspector who checked my 81 and told me that it had been severely wrecked and repaired once before. My wife got so many tickets in it that she got her license suspended and I sold it.
#14 |
Re: cat converters
Adding cats can help with exhaust smell but you should try tuning and moving the exhaust outlet as far back as possible before doing anything else. And have the exhaust point towards the back.
There’s a reason people always complain about the exhaust smell after removing cats from cars(mostly modern cars since the cats are more effective this making a bigger difference).
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
#15 | |
Re: cat converters
#16 | ||
Re: cat converters
#17 | |
Re: cat converters
Bad cats that need to be replace stink. The exhaust on my 2K Cad DTS that I don't have anymore stunk with some brands of gas but the cats were in place and functioning and the car was tuned.
