08-13-2020, 02:12 AM | #1 |
70+ ( Old Skool Club )
Adding Rear Sway Bar Question
I have a Hellwig Rear Sway bar and will have to install while truck on ground. Instruction say the weight of the truck needs to be onthe suspension when its installed. If I jack up he truck and put jack stands under the axle is it the same as having the truck sitting on the ground.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
08-13-2020, 04:40 AM | #2 |
Re: Adding Rear Sway Bar Question
When I put my QA1 suspension on, and went to set the sway bars I put jack stands on the rear axel and both lower control arms in the front. I also set it as close as I could to ride height.
08-13-2020, 05:16 PM | #3 | |
08-14-2020, 01:17 AM | #4 |
Thanks, I kinda thought that might be the right way as then the truck is level withthe weigh on the suspension.
08-20-2020, 10:54 AM | #5 |
I'm curious as to why you need to put it on jack stands? When I installed my rear sway bar, there was plenty of room with the truck on the ground.
72 C10 lwb fleetside -stock 350/350 combo |
08-20-2020, 01:08 PM | #6 | |
Lower truck? More room to work? Just 'cause....?
08-20-2020, 04:53 PM | #7 |
Yep, #'s 1-3 and 4
08-20-2020, 05:13 PM | #8 |
08-21-2020, 11:26 AM | #9 |
