Removing inner fenders
Anybody had success removing the front inner fenders on a '53 3100 without removing the fenders? Is it possible?
Re: Removing inner fenders
Sure, it's possible. First you get out your plasma cutter, Sawzall, and 4" cutoff wheels...
![]() But seriously folks...I've never tried removing inner fenders individually, but I have tried to install them after the fenders and it was virtually impossible. At the very least you'd have to loosen the outer fenders so much that you might as well just remove them.
1951 Chevy Panel Truck Last edited by MiraclePieCo; 08-22-2020 at 11:03 PM. |
![]() Join Date: May 2007
I think you would spend more time trying to do it with the fenders in place than you would just taking the fender and inner off as one chunk. take the latch panel off, take the grille out, unbolt the fender at the cab and toe board, unbolt the inner fender support at the core support, a couple more bolts at the core support and it will all slide apart.
rusty bolts breaking is probably your fear, right? on the core support soak em with a mix of acetone and atf, same with the toe board on the drivers side. on the passenger toe board and on the cab to fender bolts, you are better off just resigning yourself to new hardware and TIGHTENING to snap the through bolts. the reason you snap those but take care of the core support is because through bolts are easily replaced but drilling out broken bolts in the core support and toe board nutserts is no way to spend an afternoon (a weekend)
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
I have to go along with them, it would be a far bigger fight to do it with the fender on than remove the fender in the first place.
You do have to remove the latch panel to reach the screws behind the grill and remove the fender to body bolts but you have to take all the rest out to get the inner fender out anyhow. The fender will come off without removing the grill completely. I did it on my 48 when it got wrecked in the 70's.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 08-23-2020 at 12:08 PM. |
